<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOMIC SPK Base (NS4168) UIFlow2 examples?]]></title><description><![CDATA[<p dir="auto">Hello,<br />
is there an example of using the  ATOMIC SPK Base (NS4168) in UIFlow2 ?</p>
<p dir="auto"><img src="/assets/uploads/files/1732827232915-screenshot-from-2024-11-28-21-53-28.png" alt="Screenshot from 2024-11-28 21-53-28.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I configured the I2S pins following the pins indicated at the bottom of <a href="https://docs.m5stack.com/en/atom/Atomic%20SPK%20Base" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/atom/Atomic SPK Base</a><br />
using Atom matrix, however I have not managed to get any audio out.</p>
<p dir="auto">( I also read the "Atomic SPK Base Some IO conflict with ATOM Matrix's built-in hardware, soAtomic SPK Base is only applicable to ATOM LITE/ATOMS3 LITE" warning, but looking at the schematics and the pin-compatibility table unclear what that problem could be.)</p>
<p dir="auto">Thanks for your help.</p>
]]></description><link>https://community.m5stack.com/topic/7030/atomic-spk-base-ns4168-uiflow2-examples</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 20:44:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7030.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Nov 2024 20:56:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOMIC SPK Base (NS4168) UIFlow2 examples? on Fri, 06 Dec 2024 12:17:24 GMT]]></title><description><![CDATA[<p dir="auto">The ATOMIC SPK Base (NS4168) with UIFlow2 is compatible with various example projects for robotics and IoT. You can find UIFlow2 examples on the official Atomic Pi documentation or their GitHub repository for ready-to-use sample codes.</p>
]]></description><link>https://community.m5stack.com/post/27373</link><guid isPermaLink="true">https://community.m5stack.com/post/27373</guid><dc:creator><![CDATA[peolsolutions]]></dc:creator><pubDate>Fri, 06 Dec 2024 12:17:24 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMIC SPK Base (NS4168) UIFlow2 examples? on Thu, 28 Nov 2024 23:40:36 GMT]]></title><description><![CDATA[<p dir="auto">Solution found!</p>
<p dir="auto">Looking around at examples in <a href="https://docs.micropython.org/en/latest/library/machine.I2S.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.micropython.org/en/latest/library/machine.I2S.html</a><br />
I noticed that the I2S "id: identifies a particular I2S bus; it is board and port specific" was set to 2.</p>
<p dir="auto">Changing "I2S port" from 0 to 2, and keeping everything else the same; made things work.</p>
]]></description><link>https://community.m5stack.com/post/27208</link><guid isPermaLink="true">https://community.m5stack.com/post/27208</guid><dc:creator><![CDATA[rodrigob]]></dc:creator><pubDate>Thu, 28 Nov 2024 23:40:36 GMT</pubDate></item></channel></rss>
