<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5CoreS3 compatibility with BaseAAA]]></title><description><![CDATA[<p dir="auto">When used BaseAAA with M5CoreS3 then when turned on only display blink is visible but device not starts. Should this two devices work together?</p>
]]></description><link>https://community.m5stack.com/topic/7004/m5cores3-compatibility-with-baseaaa</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 21:57:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7004.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Nov 2024 16:53:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5CoreS3 compatibility with BaseAAA on Fri, 29 Nov 2024 10:02:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hynekt" aria-label="Profile: HynekT">@<bdi>HynekT</bdi></a><br />
It should not work. BaseAAA output is only 4V, while CoreS3 requires BUS input of 5V. The input voltage of Core Basic and Core2 is only 3.7V, so it is usable. I suggest using Base DIN for CoreS3.</p>
]]></description><link>https://community.m5stack.com/post/27222</link><guid isPermaLink="true">https://community.m5stack.com/post/27222</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 29 Nov 2024 10:02:29 GMT</pubDate></item></channel></rss>
