<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Burner on Apple M2 Ventura 13.6 Is Unstable]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I hope you can help me with the following issue:</p>
<p dir="auto">Controller tested: ATOMS3 and ESP32-S3-BOX-3<br />
Mac OS: Ventura 13.6<br />
Host computer: MacBook Air, M2 silicon  (two computers tested)</p>
<p dir="auto">After the controller is connected, M5Burner repeatedly shows the message: "Found New Device"<br />
<img src="/assets/uploads/files/1731034310297-screenshot-2024-11-08-at-10.48.47.png" alt="Screenshot 2024-11-08 at 10.48.47.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It is impossible to flash the controller with a demo program. The following message is shown after the flashing failed:</p>
<pre><code>--chip auto --port /dev/tty.usbmodem11412101 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x000 /Applications/M5Burner.app/Contents/Resources/packages/firmware/ffd26b8ba73aefa2a964e2f56d39f1e6.bin
esptool.py v4.7-dev
Serial port /dev/tty.usbmodem11412101
Connecting...
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 20, in &lt;module&gt;
    esptool._main()
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/__init__.py", line 1073, in _main
    main()
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/__init__.py", line 678, in main
    esp = esp or get_default_connected_device(
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/__init__.py", line 956, in get_default_connected_device
    _esp = detect_chip(
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/cmds.py", line 94, in detect_chip
    detect_port.connect(connect_mode, connect_attempts, detecting=True)
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/loader.py", line 647, in connect
    last_error = self._connect_attempt(reset_strategy, mode)
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/loader.py", line 548, in _connect_attempt
    self._port.flushOutput()
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/serial/serialutil.py", line 587, in flushOutput
    self.reset_output_buffer()
  File "/Applications/M5Burner.app/Contents/Resources/packages/tool/serial/serialposix.py", line 604, in reset_output_buffer
    termios.tcflush(self.fd, termios.TCOFLUSH)
termios.error: (6, 'Device not configured')
<p dir="auto">Flashing the same controllers from a Windows PC works without any issues.<br />
Flashing the same controllers using ESP-IDF and MackBook works without any issues.</p>
]]></description><link>https://community.m5stack.com/topic/6968/m5burner-on-apple-m2-ventura-13-6-is-unstable</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 23:01:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6968.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Nov 2024 02:54:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Burner on Apple M2 Ventura 13.6 Is Unstable on Mon, 11 Nov 2024 04:35:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> and <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/168201">@kuriko</a>,</p>
<p dir="auto">I resolved the issue with flashing by manually putting the devices into bootloader mode.</p>
<p dir="auto">In particular, for ATOMS3 the trick was to "press and hold the reset button (about 2 seconds) until the internal green LED lights up" as written in the manual :)</p>
<p dir="auto">Thank you for your replies and kind help!</p>
]]></description><link>https://community.m5stack.com/post/27010</link><guid isPermaLink="true">https://community.m5stack.com/post/27010</guid><dc:creator><![CDATA[krzychb]]></dc:creator><pubDate>Mon, 11 Nov 2024 04:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner on Apple M2 Ventura 13.6 Is Unstable on Sat, 09 Nov 2024 08:00:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/181239">@krzychb</a> S3 based devices are different to previous gen devices.<br />
You have to hold the boot button down to put them into boot loader mode like Raspberry pi's</p>
]]></description><link>https://community.m5stack.com/post/26998</link><guid isPermaLink="true">https://community.m5stack.com/post/26998</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 Nov 2024 08:00:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner on Apple M2 Ventura 13.6 Is Unstable on Fri, 08 Nov 2024 10:00:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/181239">@krzychb</a><br />
M5Burner is not very stable on macOS at the moment, but this problem does not occur on my 2021 MacBook Pro with macOS Sequoia 15.1</p>
]]></description><link>https://community.m5stack.com/post/26993</link><guid isPermaLink="true">https://community.m5stack.com/post/26993</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 08 Nov 2024 10:00:03 GMT</pubDate></item></channel></rss>
