<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom S3R - Screen Dead on Arival]]></title><description><![CDATA[<p dir="auto">I received an Atom S3R and the screen doesn't work.  I've erased and installed the correct firmware and still no screen.  Anyone know any tricks to get working?</p>
]]></description><link>https://community.m5stack.com/topic/6921/atom-s3r-screen-dead-on-arival</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 12:15:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6921.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Oct 2024 16:22:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atom S3R - Screen Dead on Arival on Mon, 11 Nov 2024 10:24:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a> I bought it at the M5 store and as returning the item is impossible, I will have to throw it in the trash. Here's a tip NOT to buy the AtomS3, because from what I've seen, it's a chronic problem with the device and a lot of people have the same problem</p>
]]></description><link>https://community.m5stack.com/post/27011</link><guid isPermaLink="true">https://community.m5stack.com/post/27011</guid><dc:creator><![CDATA[atmozphera]]></dc:creator><pubDate>Mon, 11 Nov 2024 10:24:24 GMT</pubDate></item><item><title><![CDATA[Reply to Atom S3R - Screen Dead on Arival on Fri, 08 Nov 2024 09:57:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atmozphera" aria-label="Profile: atmozphera">@<bdi>atmozphera</bdi></a><br />
Since you have tried so many things, it should be determined that this is a hardware problem and you should contact the seller.</p>
]]></description><link>https://community.m5stack.com/post/26992</link><guid isPermaLink="true">https://community.m5stack.com/post/26992</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 08 Nov 2024 09:57:39 GMT</pubDate></item><item><title><![CDATA[Reply to Atom S3R - Screen Dead on Arival on Fri, 08 Nov 2024 05:15:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I also have a recently purchased AtomS3 (about 2 months ago) and today, out of nowhere, the screen died and nothing appears anymore.</p>
<p dir="auto">Nothing bad was done on it, a project was running normally. I've done everything until now:</p>
<li>I've reset it, nothing work.</li>
<li>I flashed the project again successfully (its hit 100% but nothing appears on the screen.</li>
<p dir="auto">I did the reset, erase, etc, etc.. and nothing.</p>
<p dir="auto">Other projects, such as Ui2Flow2, load 100%, without any errors, but nothing is displayed on the screen. Leading me to believe that the screen simply burned out.</p>
<p dir="auto">Is there anything else I can try or should I throw it in the trash?</p>
<p dir="auto">Best regards,</p>
]]></description><link>https://community.m5stack.com/post/26991</link><guid isPermaLink="true">https://community.m5stack.com/post/26991</guid><dc:creator><![CDATA[atmozphera]]></dc:creator><pubDate>Fri, 08 Nov 2024 05:15:43 GMT</pubDate></item><item><title><![CDATA[Reply to Atom S3R - Screen Dead on Arival on Mon, 04 Nov 2024 22:08:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a><br />
It does appear in the device list and I've flashed it with the proper firmware through the UIFlow program.  Even tried erasing first.  M5 sent me a coupon to replace it, but there's no Atom S3R's in stock right now.  Will get a new one when they are available.</p>
]]></description><link>https://community.m5stack.com/post/26948</link><guid isPermaLink="true">https://community.m5stack.com/post/26948</guid><dc:creator><![CDATA[Kramph]]></dc:creator><pubDate>Mon, 04 Nov 2024 22:08:55 GMT</pubDate></item><item><title><![CDATA[Reply to Atom S3R - Screen Dead on Arival on Thu, 24 Oct 2024 03:49:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kramph,<br />
Have you tried to burning the UIFlow firmware? Does the device appear in the UIFlow device list?</p>
]]></description><link>https://community.m5stack.com/post/26826</link><guid isPermaLink="true">https://community.m5stack.com/post/26826</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Thu, 24 Oct 2024 03:49:25 GMT</pubDate></item></channel></rss>
