<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pa hub]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I have the Pa Hub (PCA 9548AP).  WHen I plug it into the Core S3 it registers it's address and shows up on the i2c bus but anything plugged into it doesn't.  The units work fine directly connected though.   I.e. code works on sensor directly plugged in but does not when the hub is used and the sensor is plugged into that.  Do I need a driver or am I doing something wrong?</p>
<p dir="auto">Bipman</p>
]]></description><link>https://community.m5stack.com/topic/6912/pa-hub</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 14:25:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6912.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Oct 2024 19:45:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pa hub on Thu, 24 Oct 2024 11:10:37 GMT]]></title><description><![CDATA[<p dir="auto">Thanks everyone!</p>
]]></description><link>https://community.m5stack.com/post/26832</link><guid isPermaLink="true">https://community.m5stack.com/post/26832</guid><dc:creator><![CDATA[Bipman]]></dc:creator><pubDate>Thu, 24 Oct 2024 11:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to Pa hub on Mon, 21 Oct 2024 19:45:16 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bipman" aria-label="Profile: Bipman">@<bdi>Bipman</bdi></a></p>
<p dir="auto">PaHub can be used as simple hub as long as no connected unit is using its I2C address of 0x70.</p>
<p dir="auto">See example in UIFlow2 Project Zone: <em>M5Core_PaHub_As_Simple_Hub_UIFlow2.1.5</em></p>
]]></description><link>https://community.m5stack.com/post/26815</link><guid isPermaLink="true">https://community.m5stack.com/post/26815</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 21 Oct 2024 19:45:16 GMT</pubDate></item><item><title><![CDATA[Reply to Pa hub on Mon, 21 Oct 2024 16:36:30 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bipman" aria-label="Profile: Bipman">@<bdi>Bipman</bdi></a></p>
<p dir="auto">you probably don't need a PaHub for your setup.</p>
<p dir="auto">If the I2C units you want to connect all have <strong>different</strong> I2C addresses a simple Grove <a href="https://docs.m5stack.com/en/unit/hub" target="_blank" rel="noopener noreferrer nofollow ugc">hub</a> is enough.</p>
<p dir="auto">PaHub is only required if you want to connect I2C units which share the <strong>same</strong> I2C address.</p>
]]></description><link>https://community.m5stack.com/post/26812</link><guid isPermaLink="true">https://community.m5stack.com/post/26812</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 21 Oct 2024 16:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to Pa hub on Mon, 21 Oct 2024 08:59:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> I've tried the BME280, the heart rate monitor, the OLED Unit to name a few.</p>
]]></description><link>https://community.m5stack.com/post/26808</link><guid isPermaLink="true">https://community.m5stack.com/post/26808</guid><dc:creator><![CDATA[Bipman]]></dc:creator><pubDate>Mon, 21 Oct 2024 08:59:24 GMT</pubDate></item><item><title><![CDATA[Reply to Pa hub on Sun, 20 Oct 2024 19:51:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bipman" aria-label="Profile: Bipman">@<bdi>Bipman</bdi></a> What sensor are you trying?</p>
]]></description><link>https://community.m5stack.com/post/26802</link><guid isPermaLink="true">https://community.m5stack.com/post/26802</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sun, 20 Oct 2024 19:51:42 GMT</pubDate></item></channel></rss>
