<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to burn firmware for Core device]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
I have a m5 stack Core, it came originally from the factory with UIFlow and it shows version 1.11.6<br />
I am on Windows and this is what I did to flash the new firmware UIFlow 2:</p>
<li>downloaded the latest Burner tool</li>
<li>connect to Windows host via factory usb cable</li>
<li>hit USB mode</li>
<li>verify that on Windows the serial COM5 port is enabled</li>
<li>launch the Burner</li>
<li>select the port</li>
<p dir="auto">This error happens</p>
<p dir="auto"><img src="/assets/uploads/files/1729269528548-805a3499-e769-4c44-aab3-9ffd2572e6f0-image.png" alt="805a3499-e769-4c44-aab3-9ffd2572e6f0-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The core device shows the USB green logo on the top left corner but nothing is happening on the screen.<br />
Let me know how to sort it.</p>
<p dir="auto">PS<br />
Also tried as admin.<br />
Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/6906/unable-to-burn-firmware-for-core-device</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 01:12:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6906.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Oct 2024 16:39:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to burn firmware for Core device on Sat, 02 Nov 2024 15:01:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/40326">@leo-ninja-turtle</a> Have you installed USB drivers?<br />
Are you using a working sync cable?</p>
]]></description><link>https://community.m5stack.com/post/26931</link><guid isPermaLink="true">https://community.m5stack.com/post/26931</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 02 Nov 2024 15:01:42 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to burn firmware for Core device on Sat, 02 Nov 2024 10:49:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/40326">@leo-ninja-turtle</a> Any pointers so far? Did anyone manage to flash the module with UiFlow2?</p>
]]></description><link>https://community.m5stack.com/post/26926</link><guid isPermaLink="true">https://community.m5stack.com/post/26926</guid><dc:creator><![CDATA[leo-ninja-turtle]]></dc:creator><pubDate>Sat, 02 Nov 2024 10:49:28 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to burn firmware for Core device on Sun, 20 Oct 2024 16:15:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a> It means this is the first time I am trying to flash it with new firmware.</p>
]]></description><link>https://community.m5stack.com/post/26800</link><guid isPermaLink="true">https://community.m5stack.com/post/26800</guid><dc:creator><![CDATA[leo-ninja-turtle]]></dc:creator><pubDate>Sun, 20 Oct 2024 16:15:53 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to burn firmware for Core device on Fri, 18 Oct 2024 19:24:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/40326">@leo-ninja-turtle</a> said in <a href="/post/26778">Unable to burn firmware for Core device</a>:<br />
Not sure what you mean by:</p>
<p dir="auto">it came originally from the factory with UIFlow</p>
]]></description><link>https://community.m5stack.com/post/26782</link><guid isPermaLink="true">https://community.m5stack.com/post/26782</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Fri, 18 Oct 2024 19:24:28 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to burn firmware for Core device on Fri, 18 Oct 2024 16:46:43 GMT]]></title><description><![CDATA[<p dir="auto">Okay it was a faulty cable, now with a proper USB the connection was successful:</p>
<p dir="auto"><img src="/assets/uploads/files/1729269964551-c4e9ca11-af50-4955-884a-b02aa7494580-image.png" alt="c4e9ca11-af50-4955-884a-b02aa7494580-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Log</p>
<p dir="auto">Burning<br />
--chip auto --port COM3 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x9000 D:\Users\robom\Downloads\M5Burner-v3-beta-win-x64\packages\tmp\uiflow2-cfg.bin<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v4.6.2<br />
Serial port COM3<br />
Connecting...<br />
.</p>
<p dir="auto">Detecting chip type... Unsupported detection protocol, switching and trying again...<br />
Connecting...<br />
.<br />
.</p>
<p dir="auto">Detecting chip type...<br />
ESP32<br />
Chip is ESP32-D0WDQ6-V3 (revision v3.0)<br />
Crystal is 40MHz<br />
MAC: 78:21:84:a5:fd:98<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Changing baud rate to 1500000<br />
Changed.<br />
Auto-detected Flash size: 16MB<br />
Flash will be erased from 0x00009000 to 0x0000efff...<br />
Compressed 24576 bytes to 475...<br />
Writing at 0x00009000... (100 %)<br />
Wrote 24576 bytes (475 compressed) at 0x00009000 in 0.3 seconds (effective 663.1 kbit/s)...<br />
Hash of data verified.</p>
<p dir="auto">Leaving...<br />
Hard resetting via RTS pin...</p>
<p dir="auto">However after that I still see v1.11.6</p>
]]></description><link>https://community.m5stack.com/post/26779</link><guid isPermaLink="true">https://community.m5stack.com/post/26779</guid><dc:creator><![CDATA[leo-ninja-turtle]]></dc:creator><pubDate>Fri, 18 Oct 2024 16:46:43 GMT</pubDate></item></channel></rss>
