<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5GO Battery Bottom3 (for CoreS3 only) with CoreS3 issues]]></title><description><![CDATA[<p dir="auto">M5GO Battery Bottom3 (for CoreS3 only) was delivered today for my CoreS3.  Also delivered was a M5GO/FIRE Battery Bottom Charging Base</p>
<p dir="auto">I installed it and while the battery is working, when I put it on the M5GO/FIRE Battery Bottom Charging Base the USB-C charging input doesn't deliver charge to the battery nor data.</p>
<p dir="auto">Further, I assumed the LEDs included in the M5GO Battery Bottom3 (for CoreS3 only) would be useable with the RGB function of UiFlow2, but this doesn't seem to work.</p>
<p dir="auto">Do I need to do something special with the CoreS3 to get these functions to work?</p>
]]></description><link>https://community.m5stack.com/topic/6776/m5go-battery-bottom3-for-cores3-only-with-cores3-issues</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Mar 2026 11:57:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6776.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Sep 2024 05:06:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5GO Battery Bottom3 (for CoreS3 only) with CoreS3 issues on Sun, 08 Sep 2024 01:20:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a></p>
<p dir="auto">OKAY!  Excellent.  THANK YOU.  Didn't understand the USB-C port on the charging base.</p>
<p dir="auto">Figured this all out with your help and appears to need to be fed the power from the included "dumb" USB-A to USB-C cable and not what I thought I could do from an Apple USB-C / USB-C plugged into my MacBook.</p>
<p dir="auto">Problem solved!</p>
<p dir="auto">Thank you again!</p>
]]></description><link>https://community.m5stack.com/post/26387</link><guid isPermaLink="true">https://community.m5stack.com/post/26387</guid><dc:creator><![CDATA[Coopersmith-24601]]></dc:creator><pubDate>Sun, 08 Sep 2024 01:20:28 GMT</pubDate></item><item><title><![CDATA[Reply to M5GO Battery Bottom3 (for CoreS3 only) with CoreS3 issues on Sat, 07 Sep 2024 23:41:35 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/152984">@Coopersmith-24601</a></p>
<p dir="auto">glad to hear that the RGB example helped.</p>
<p dir="auto">The four pogo pins are GND, 5V, SDA and SCL. E.g. power and I2C. See top right corner of <a href="https://docs.m5stack.com/en/module/M5GO3%20Bottom?id=schematic" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> - <em>Socket_Power_4P</em>.</p>
<p dir="auto">Firmware download uses a serial connection and not I2C. In other words the <em>M5GO/FIRE Battery Bottom Charging Base</em> can only be used to charge the battery.</p>
<p dir="auto">Edit: I just confirmed by opening it: only GND and 5 V are connected at the USB-C port.</p>
<p dir="auto">How do you know the battery isn't getting charged? Isn't there a red (or green) light?</p>
]]></description><link>https://community.m5stack.com/post/26386</link><guid isPermaLink="true">https://community.m5stack.com/post/26386</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 07 Sep 2024 23:41:35 GMT</pubDate></item><item><title><![CDATA[Reply to M5GO Battery Bottom3 (for CoreS3 only) with CoreS3 issues on Sat, 07 Sep 2024 22:47:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a></p>
<p dir="auto">Thank you for that programming example.  It cleared up how to use the RGB LEDs and that's great!</p>
<p dir="auto">However, I still have an unresolved issue with the M5GO/FIRE Battery Bottom Charging Base; <a href="https://shop.m5stack.com/products/battery-bottom-charging-base" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/battery-bottom-charging-base</a></p>
<p dir="auto">If I plug a USB-C cable into it, the power doesn't pass power to the M5GO Battery Bottom3 (for CoreS3 only) through the pogo pins and doesn't charge its 500mAh battery; <a href="https://shop.m5stack.com/products/m5go-battery-bottom3-for-cores3-only" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/m5go-battery-bottom3-for-cores3-only</a></p>
<p dir="auto">Just to be clear, I'm also using these with a CoreS3; <a href="https://shop.m5stack.com/products/m5stack-cores3-esp32s3-lotdevelopment-kit" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/m5stack-cores3-esp32s3-lotdevelopment-kit</a></p>
<p dir="auto">I've removed the CoreS3 bottom and replaced it with the M5GO Battery Bottom3 (for CoreS3 only).  If I attempt to use the USB-C port on the <strong>M5GO/FIRE Battery Bottom Charging Base</strong>, just like the power issue above, I also can't use it to send firmware to the CoreS3 (which is what I meant in my previous post by data).  It's as if the M5GO/FIRE Battery Bottom Charging Base is entirely useless for either charging the battery or programming.  That doesn't seem like it should be the case at all.</p>
]]></description><link>https://community.m5stack.com/post/26385</link><guid isPermaLink="true">https://community.m5stack.com/post/26385</guid><dc:creator><![CDATA[Coopersmith-24601]]></dc:creator><pubDate>Sat, 07 Sep 2024 22:47:27 GMT</pubDate></item><item><title><![CDATA[Reply to M5GO Battery Bottom3 (for CoreS3 only) with CoreS3 issues on Sat, 07 Sep 2024 06:22:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/152984">@Coopersmith-24601</a></p>
<p dir="auto">Re charging: the M5GO3 has its own charger IC built-in. A red LED indicates charging and when the battery is full the green LED in M5GO3 lights up. The built-in charger IC cannot be queried by software; is that what you mean by 'data'?</p>
<p dir="auto">Re RGB: please find an example in the UIFlow2 Project Zone: <em>M5CoreS3_M5G03Bottom_RGB_UIFlow2.1.3</em></p>
]]></description><link>https://community.m5stack.com/post/26377</link><guid isPermaLink="true">https://community.m5stack.com/post/26377</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 07 Sep 2024 06:22:14 GMT</pubDate></item></channel></rss>
