<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stick2 &#x2F; Leption Thermal Option - Repo broken]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">we got our M5Stick2 with the Leption Thermal Option, first of all, many thanks to M5Stack for a new tiny sexy IoT Device!</p>
<p dir="auto">Product-Link:<br />
<a href="https://docs.m5stack.com/en/core/m5stickt" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/core/m5stickt</a></p>
<p dir="auto">In the Document Section we could find two Sections, one for the Stock Firmware found here.</p>
<p dir="auto"><a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/EasyLoader/Windows/CORE/EasyLoader_M5StickT_FactoryTest.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/EasyLoader/Windows/CORE/EasyLoader_M5StickT_FactoryTest.exe</a></p>
<p dir="auto">We are able to load the Firmware and the Device will run as expected.</p>
<p dir="auto">But for our upcoming Projects we need to integrate the the M5Stick2 with the Leption Thermal Option in other Platforms, so we need to extend the Firmware here supporting RTSP Streaming.</p>
<p dir="auto">So in the second Section of the official Documents, we found the Link to the<br />
Github-Repository.</p>
<p dir="auto">Github Link:<br />
<a href="https://github.com/m5stack/M5-StickT" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-StickT</a></p>
<p dir="auto">We downloaded the Repo and got it compiled with the Boards<br />
M5StickC and M5StickCPlus</p>
<p dir="auto">Question here, will there a New Bord come for M5Stick2?</p>
<p dir="auto">However, when we build the Code on the Arduino IDE we not get any Errors, we could also transfer the compiled file to the Device.</p>
<p dir="auto">After the Hard resetting via RTS pin, the Device starts endless looping</p>
<p dir="auto">here the Output from the SerialMonitor...</p>
<p dir="auto"><em><strong><strong><strong>snip</strong></strong></strong></em>____________<br />
*rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)<br />
configsip: 188777542, SPIWP:0xee<br />
mode:DIO, clock div:1</p>
<p dir="auto">load:0x40078000,len:13964<br />
load:0x40080400,len:3600<br />
entry 0x400805f0<br />
M5StickC initializing...OK</p>
<p dir="auto">E (1602) gpio: GPIO can only be used as input mode<br />
Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.<br />
Memory dump at 0x400d1c78: 530c0504 00000239 91004136<br />
Core  1 register dump:</p>
<p dir="auto">PC      : 0x400d1c7e  PS      : 0x00060a30  A0      : 0x800d1a71  A1      : 0x3ffb2220<br />
A2      : 0x3ffc1e1c  A3      : 0x00000005  A4      : 0x00000087  A5      : 0x00000001<br />
A6      : 0x00000001  A7      : 0x00001000  A8      : 0x800d1c7a  A9      : 0x3ffb2200<br />
A10     : 0x000003e8  A11     : 0x00000000  A12     : 0xffffffff  A13     : 0x00000022<br />
A14     : 0x00000023  A15     : 0x00000001  SAR     : 0x00000020  EXCCAUSE: 0x00000000<br />
EXCVADDR: 0x00000000  LBEG    : 0x40085021  LEND    : 0x40085029  LCOUNT  : 0x00000027</p>
<p dir="auto">Backtrace: 0x400d1c7b:0x3ffb2220 0x400d1a6e:0x3ffb2250 0x400d7f82:0x3ffb2290</p>
<p dir="auto">ELF file SHA256: 41ffe27bd9eb02c2*</p>
<p dir="auto"><em><strong><strong><strong>snip</strong></strong></strong></em>____________</p>
<p dir="auto">We used an other Scetch from Github from the M5Stack Repos which use also the Lepton Thermal Option</p>
<a href="https://github.com/m5stack/M5_WirelessT" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5_WirelessT</a></p>
<p dir="auto">here we have exact the same behavior, we could compile it, load it and the Device ends in a endless loop.</p>
<p dir="auto">Please fix ASAP the the official M5Repo under <a href="https://github.com/m5stack/M5-StickT" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-StickT</a> for the new M5Stick2 Hardware or update the Board Defenitions, because all Sketches comprising on the 4 Years old Repo, will not work for your End Customers.</p>
<p dir="auto">Please help, becasue we have upcoming Projekts using the M5Stick2 / Leption Thermal Option.</p>
<p dir="auto">Best Regards</p>
]]></description><link>https://community.m5stack.com/topic/6764/m5stick2-leption-thermal-option-repo-broken</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 22:31:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6764.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Sep 2024 07:54:36 GMT</pubDate><ttl>60</ttl></channel></rss>
