<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Multi-channel current measurement using PaHub and ADC Unit, results are lower than w&#x2F;o PaHub]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I am currently using m5stack and ADC Unit to measure target AC cables.<br />
However, when I attempted to use PaHub and 2 ADC Units to create a multi-channel system, the outputs are 20-30% lower than the results of using simply one ADC unit.</p>
<p dir="auto">Previously, there are a couple of solutions in this forum, like:<br />
<a href="https://community.m5stack.com/topic/3040/adc-unit-major-problem?lang=ja">https://community.m5stack.com/topic/3040/adc-unit-major-problem?lang=ja</a><br />
<a href="https://community.m5stack.com/topic/1107/solved-fire-pahub-adc-ads1100">https://community.m5stack.com/topic/1107/solved-fire-pahub-adc-ads1100</a><br />
I really appreciate it!</p>
<p dir="auto"><strong>However, is there any solution without removing the resistors in ADC unit? Instead, is that possible to remove any resistors in PaHub to correct the outputs?</strong></p>
<p dir="auto">Any does anyone know the reason/principle of removing resistors?</p>
<p dir="auto">Thank you very much and I appreciate any reply.</p>
]]></description><link>https://community.m5stack.com/topic/6754/multi-channel-current-measurement-using-pahub-and-adc-unit-results-are-lower-than-w-o-pahub</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 14:43:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6754.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Sep 2024 07:20:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Multi-channel current measurement using PaHub and ADC Unit, results are lower than w&#x2F;o PaHub on Tue, 03 Sep 2024 00:22:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a></p>
<p dir="auto">Thank you very much.<br />
Power booster sounds like a pretty good solution.</p>
<p dir="auto">I apologize that I am a beginner of this field, if possible, could you please inform me why removing resistors of ADC Unit corrects the current output?</p>
<p dir="auto">Since I also tried to remove several resistors in PaHub, however, the readings increased only a little bit..</p>
]]></description><link>https://community.m5stack.com/post/26323</link><guid isPermaLink="true">https://community.m5stack.com/post/26323</guid><dc:creator><![CDATA[Richelieu]]></dc:creator><pubDate>Tue, 03 Sep 2024 00:22:52 GMT</pubDate></item><item><title><![CDATA[Reply to Multi-channel current measurement using PaHub and ADC Unit, results are lower than w&#x2F;o PaHub on Mon, 02 Sep 2024 15:51:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/152599">@Richelieu</a> said in <a href="/post/26317">Multi-channel current measurement using PaHub and ADC Unit, results are lower than w/o PaHub</a>:</p>
<p dir="auto">Thank you very much and I appreciate any reply.<br />
Sounds like a power issue, may need to add a power booster</p>
]]></description><link>https://community.m5stack.com/post/26321</link><guid isPermaLink="true">https://community.m5stack.com/post/26321</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 02 Sep 2024 15:51:32 GMT</pubDate></item></channel></rss>
