<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[esp32 to usb driver issues.]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1724459759168-screenshot-2024-08-23-184148.png" alt="Screenshot 2024-08-23 184148.png" class=" img-fluid img-markdown" /><br />
I recently purchased an M5Stamp Pico and a USB to TTL converter from Amazon. The converter uses the CP2102 chip. I connected the 3.3v, TX, RX, and ground pins, and shorted the ground to G0. However, Windows does not recognize the USB board. I have attempted to download various drivers for the CP2102 chip, but none have resolved the issue. Can someone please give some advice to get the board to function?</p>
<p dir="auto">Amazon Link: <a href="https://www.amazon.com/dp/B00LODGRV8?ref=ppx_yo2ov_dt_b_fed_asin_title#" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.com/dp/B00LODGRV8?ref=ppx_yo2ov_dt_b_fed_asin_title#</a></p>
]]></description><link>https://community.m5stack.com/topic/6725/esp32-to-usb-driver-issues</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 04:41:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6725.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Aug 2024 00:36:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to esp32 to usb driver issues. on Wed, 04 Sep 2024 15:23:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> I have tried it with a different usb to ttl bridge with the same results, and m5burner gives me the exact same error as arduino IDE</p>
]]></description><link>https://community.m5stack.com/post/26353</link><guid isPermaLink="true">https://community.m5stack.com/post/26353</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Wed, 04 Sep 2024 15:23:26 GMT</pubDate></item><item><title><![CDATA[Reply to esp32 to usb driver issues. on Wed, 04 Sep 2024 13:18:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> have you tried different usb cables? if you have m5burner opened and you plug your M5 unit to usb ids there any com port detection visible at all?</p>
]]></description><link>https://community.m5stack.com/post/26351</link><guid isPermaLink="true">https://community.m5stack.com/post/26351</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Wed, 04 Sep 2024 13:18:45 GMT</pubDate></item><item><title><![CDATA[Reply to esp32 to usb driver issues. on Wed, 04 Sep 2024 11:59:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>  Yes I have with no similar luck</p>
]]></description><link>https://community.m5stack.com/post/26350</link><guid isPermaLink="true">https://community.m5stack.com/post/26350</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Wed, 04 Sep 2024 11:59:00 GMT</pubDate></item><item><title><![CDATA[Reply to esp32 to usb driver issues. on Wed, 04 Sep 2024 04:51:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> have you tried a different adapter like an arduino uno in ISP mode of the M5Stack adapter?</p>
]]></description><link>https://community.m5stack.com/post/26343</link><guid isPermaLink="true">https://community.m5stack.com/post/26343</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 04 Sep 2024 04:51:55 GMT</pubDate></item><item><title><![CDATA[Reply to esp32 to usb driver issues. on Wed, 04 Sep 2024 01:18:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
<p dir="auto">Hey after a while for a new one to come in that seems to be the case, but now I seem to be running into a new error.</p>
<p dir="auto">WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.<br />
Configuring flash size...</p>
<p dir="auto">and I have reinstalled the drivers almost 10 times at this point. I tried it on different computers and also trying different operating systems. I also tried different ports on those computers.</p>
]]></description><link>https://community.m5stack.com/post/26342</link><guid isPermaLink="true">https://community.m5stack.com/post/26342</guid><dc:creator><![CDATA[leaguen]]></dc:creator><pubDate>Wed, 04 Sep 2024 01:18:07 GMT</pubDate></item><item><title><![CDATA[Reply to esp32 to usb driver issues. on Sat, 24 Aug 2024 06:08:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leaguen" aria-label="Profile: leaguen">@<bdi>leaguen</bdi></a> You don't short G0 on the pico to ground.</p>
<p dir="auto">It looks like your TTL adapter is not working.</p>
]]></description><link>https://community.m5stack.com/post/26216</link><guid isPermaLink="true">https://community.m5stack.com/post/26216</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 24 Aug 2024 06:08:17 GMT</pubDate></item></channel></rss>
