<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screws]]></title><description><![CDATA[<p dir="auto">Generally speaking, the Screws Situation is a nightmare.</p>
<p dir="auto">i really would love M5 to sell all Screws seperately.</p>
<p dir="auto"><a href="https://shop.m5stack.com/products/16-pcs-m3-12-18-25-32-screw-with-allen-key" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/16-pcs-m3-12-18-25-32-screw-with-allen-key</a></p>
<p dir="auto">this is good so far, but if you E.g. combine a</p>
<li>M5Stack CoreS3 SE</li>
<li>LAN Module with W5500 V12</li>
<p dir="auto">you need only the 32 Screw.<br />
so you have a lot left.</p>
<p dir="auto">also, if you stack 3 Modules together,</p>
<p dir="auto">say</p>
<li>any 13.2 Module</li>
<p dir="auto">even the longes screw of the above set is too short.</p>
<p dir="auto">M5 STack please do someting to improve this. !</p>
]]></description><link>https://community.m5stack.com/topic/6715/screws</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 11:41:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6715.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Aug 2024 10:25:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screws on Wed, 21 Aug 2024 12:59:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/franzhoepfinger" aria-label="Profile: franzhoepfinger">@<bdi>franzhoepfinger</bdi></a> M3 Socket cap bolts are generally easy to buy anywhere online and you can often get them for cheap on Amazon. The kits are only so you can work out what size M3 socket cap /hex Cap screw you may need</p>
]]></description><link>https://community.m5stack.com/post/26182</link><guid isPermaLink="true">https://community.m5stack.com/post/26182</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 21 Aug 2024 12:59:26 GMT</pubDate></item></channel></rss>
