<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stream dual USB camera on CM4Stack]]></title><description><![CDATA[<p dir="auto">I am unable to stream 2 cameras on the same USB3.2 with the following error message:<br />
"libv4l2: error turning on stream: No space left on device Unable to start capture: No space left on device"</p>
<p dir="auto">But When I have 1 USB camera connected to USB2.0 (using USB hub) then it works.</p>
<p dir="auto">Then we try to have both cameras connected to USB2.0 (via USB hub) , same above problem occurred.</p>
<p dir="auto">It seems like it only can have 1 USB camera at 1 USB controller stream per session.</p>
<p dir="auto">I have tested on other Raspberry Pi 4 and 5, they don't seems to have such issues even with both cameras on a single usb hub.</p>
]]></description><link>https://community.m5stack.com/topic/6670/stream-dual-usb-camera-on-cm4stack</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 20:47:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6670.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Aug 2024 00:44:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stream dual USB camera on CM4Stack on Sat, 03 Aug 2024 08:47:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/142667">@zhiyongwoo</a> Ahh sorry I read it as CoreMP135 not CM4stack.<br />
If it works on another CM4 then it could be something in the Kernel.<br />
Have you asked on the RPI forums ?</p>
<p dir="auto">It could be a power issue, have you checked out this discussion?  <a href="https://forums.raspberrypi.com/viewtopic.php?t=350942" target="_blank" rel="noopener noreferrer nofollow ugc">https://forums.raspberrypi.com/viewtopic.php?t=350942</a></p>
]]></description><link>https://community.m5stack.com/post/25986</link><guid isPermaLink="true">https://community.m5stack.com/post/25986</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 03 Aug 2024 08:47:08 GMT</pubDate></item><item><title><![CDATA[Reply to Stream dual USB camera on CM4Stack on Sat, 03 Aug 2024 07:13:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a><br />
If not mistaken, the CM4Stack is using CM4 module and have its own extension circuit diagram.</p>
<p dir="auto">I didn't do as I follow exactly what the document asked to do.</p>
<p dir="auto">I do have another CM4 module that connected 3rd party extension board where it gave me 4 USB ports and follow the guidance from the RPI official setup document. It is able to stream both USB camera at the same time even I have both cameras connected to an external USB3.0 hub. It doesn't report such issues.</p>
<p dir="auto">On the CM4Stack:<br />
And I want to highlight is, I can have 2 camera stream together ONLY if I have 1 connected to USB 3.2 port and 1 connected to USB 2.0</p>
<p dir="auto">So I suspect something I need to enable in Kernel level or the hardware limitation?</p>
]]></description><link>https://community.m5stack.com/post/25981</link><guid isPermaLink="true">https://community.m5stack.com/post/25981</guid><dc:creator><![CDATA[zhiyongwoo]]></dc:creator><pubDate>Sat, 03 Aug 2024 07:13:44 GMT</pubDate></item><item><title><![CDATA[Reply to Stream dual USB camera on CM4Stack on Fri, 02 Aug 2024 04:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/142667">@zhiyongwoo</a> It is not an RPI so it does not work like an RPI and doesn't have the same hardware as an RPI.</p>
<p dir="auto">BTW did you expand the partition after first boot as the initial partition is on 1 Gig and doesn't take up the whole card.</p>
]]></description><link>https://community.m5stack.com/post/25970</link><guid isPermaLink="true">https://community.m5stack.com/post/25970</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 02 Aug 2024 04:45:24 GMT</pubDate></item></channel></rss>
