<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NanoC6 or Atom Lite power&#x2F;battery - moisture]]></title><description><![CDATA[<p dir="auto">I want to create a humidity device that will turn on my ventilation above a certain threshold (it has an undocumented API I hope to use). I see there is an ENV IV unit with humidity sensor. Initially I was looking at the NanoCS but now I also see there is Atom Lite that seems very similar. Not sure which do choose. But my question would be the same for both devices I guess. And it might be a bit stupid. How do I power these things? Obviously I can use a USB-C charger but this device will be used in my bathroom where I only have one socket. So I would prefer to use batteries. Do I use put it up to a USB-C power bank? Can I use normal AA batteries somehow? What about moisture?</p>
<p dir="auto">And how long can I expect this device to run on a small battery? The app will just take humidity level as input every 10 seconds or so then if above X send a http request. Then a timer of for example 10 minutes before checking humidity level and turn off ventilation of humidity is below threshold. So power consumption wise I belive this should be quite efficient but I have no experience developing for hardware.</p>
]]></description><link>https://community.m5stack.com/topic/6635/nanoc6-or-atom-lite-power-battery-moisture</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 10:58:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6635.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jul 2024 17:48:32 GMT</pubDate><ttl>60</ttl></channel></rss>
