<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CatM+GNSS module : cellular and GNSS simultanous incompatible ?]]></title><description><![CDATA[<p dir="auto">What should have been an easy switch from the regualr sim7089 module to the CatM+GNSS module (also based on SIM7080), ended up in some serious back to basic debugging.<br />
This link (<a href="https://github.com/wottreng/SIM7080G-NB-IoT-Cat-M-LTE-GPS" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/wottreng/SIM7080G-NB-IoT-Cat-M-LTE-GPS</a>), mentions:<br />
GPS/GNSS and cellular can not be used together. Causes module to hang and be unresponsive</p>
<p dir="auto">We are going to check whether that is the cause of our issue with this module.<br />
Anyone else experience with this incompatibility.<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/6561/catm-gnss-module-cellular-and-gnss-simultanous-incompatible</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:07:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6561.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Jun 2024 13:18:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CatM+GNSS module : cellular and GNSS simultanous incompatible ? on Tue, 18 Feb 2025 14:33:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser" aria-label="Profile: HappyUser">@<bdi>HappyUser</bdi></a> is there a way to operate them bot? I'm using it with platformio so maybe is easier to achieve that micropython?</p>
]]></description><link>https://community.m5stack.com/post/28258</link><guid isPermaLink="true">https://community.m5stack.com/post/28258</guid><dc:creator><![CDATA[cuervodelviento]]></dc:creator><pubDate>Tue, 18 Feb 2025 14:33:37 GMT</pubDate></item><item><title><![CDATA[Reply to CatM+GNSS module : cellular and GNSS simultanous incompatible ? on Thu, 20 Jun 2024 07:55:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser" aria-label="Profile: HappyUser">@<bdi>HappyUser</bdi></a> First tests seem to indication that in order to switch from data mode to GNSS mode, you need to power off the GNSS module. As a result, the GNSS forgets its position and it takes another 5 to 10 seconds to get updated position data again. Btw, during the whole operation the module is powered. we are open to smarter solutions for this problem.</p>
]]></description><link>https://community.m5stack.com/post/25623</link><guid isPermaLink="true">https://community.m5stack.com/post/25623</guid><dc:creator><![CDATA[HappyUser]]></dc:creator><pubDate>Thu, 20 Jun 2024 07:55:17 GMT</pubDate></item><item><title><![CDATA[Reply to CatM+GNSS module : cellular and GNSS simultanous incompatible ? on Wed, 19 Jun 2024 11:52:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks,<br />
And now i am really curious about the Ideas from the M5Stack engineers about a fast responding program that integrates MQTT and GNSS. We are also working on it now.</p>
]]></description><link>https://community.m5stack.com/post/25610</link><guid isPermaLink="true">https://community.m5stack.com/post/25610</guid><dc:creator><![CDATA[HappyUser]]></dc:creator><pubDate>Wed, 19 Jun 2024 11:52:56 GMT</pubDate></item><item><title><![CDATA[Reply to CatM+GNSS module : cellular and GNSS simultanous incompatible ? on Tue, 18 Jun 2024 15:14:16 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser" aria-label="Profile: HappyUser">@<bdi>HappyUser</bdi></a></p>
<p dir="auto">this seems to be true. In version 1.0<strong>5</strong> (but not in older versions) of the Hardware Design <a href="https://curtocircuito.com.br/datasheet/modulo/SIM7080G_Hardware_Design.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">document</a> section <em>4.3.2 GNSS Application Guide</em> there is a note:</p>
<p dir="auto"><em>Due to the limitation by Qualcomm chipset, the LTE and GNSS RX chains of SIM7070x and SIM7080G share some hardware blocks, therefore concurrent WWAN and GNSS operations are <strong>not</strong> supported.</em></p>
]]></description><link>https://community.m5stack.com/post/25595</link><guid isPermaLink="true">https://community.m5stack.com/post/25595</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 18 Jun 2024 15:14:16 GMT</pubDate></item></channel></rss>
