<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Product] Core Stack Module: USB-C PD (as HV source and 5v system power step down)]]></title><description><![CDATA[<p dir="auto">A Core Stack module that can accept power via USB-C PD, controlled via I2C and dip switches, with option to route power over HV.<br />
On board 5v regulator to supply system power from USB-C input.<br />
Connector for external use of USB-C PD power.</p>
<p dir="auto">Dip switches could be:<br />
1: Off = HV Disconnected, On = HV Connected to USB-C PD Output<br />
3 other dip switches:<br />
000 = I2C Mode (full PPS control)<br />
001 = 5V<br />
010 = 9V<br />
011 = 15V<br />
100 = 20V<br />
101 = 28V<br />
110 = 36V<br />
111 = 48V</p>
]]></description><link>https://community.m5stack.com/topic/6532/product-core-stack-module-usb-c-pd-as-hv-source-and-5v-system-power-step-down</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 04:05:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6532.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Jun 2024 16:48:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Product] Core Stack Module: USB-C PD (as HV source and 5v system power step down) on Tue, 16 Jul 2024 14:47:24 GMT]]></title><description><![CDATA[<p dir="auto">I'd love to see this board. For Atom and Stick too. But ideally, the module would buck 5V to the controller and the controller would be able to set the output voltage of the HV circuit.</p>
<p dir="auto">I'd also love to see a charge regulator/BMS module you could plug lipo cells directly into to form 2S, 3S, 4S... circuits.</p>
]]></description><link>https://community.m5stack.com/post/25855</link><guid isPermaLink="true">https://community.m5stack.com/post/25855</guid><dc:creator><![CDATA[Amanda Hugnkiss]]></dc:creator><pubDate>Tue, 16 Jul 2024 14:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to [Product] Core Stack Module: USB-C PD (as HV source and 5v system power step down) on Sun, 30 Jun 2024 16:03:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zavyru" aria-label="Profile: Zavyru">@<bdi>Zavyru</bdi></a> Minimum PD 3.0 with PPS would be ideal, with fallback to PD 2.0, but have to somehow notify the user and not connect the HV line if PPS (or chosen voltage) isn't available; Green/Red LED maybe and only connect HV if it's green?</p>
]]></description><link>https://community.m5stack.com/post/25717</link><guid isPermaLink="true">https://community.m5stack.com/post/25717</guid><dc:creator><![CDATA[Caersons]]></dc:creator><pubDate>Sun, 30 Jun 2024 16:03:21 GMT</pubDate></item></channel></rss>
