<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[(ESP32 Ethernet Unit with PoE) Compatibility Sanity Check]]></title><description><![CDATA[<p dir="auto">Hello I was hoping if I could get some help with compatibility/feasibility check with my configuration.</p>
<p dir="auto">ESP32 Ethernet Unit with PoE + Grove2Grove Expansion Unit connected to</p>
<li>Mini CAN Unit</li>
<li>I/O Hub 1 to 6 Expansion Unit</li>
<li>Will I/O hub interfere with CAN unit?</li>
<li>Is the Grove2Grove unit necessary or can I just hook the two units up in parallel (if I don't need on/off + current meter)</li>
]]></description><link>https://community.m5stack.com/topic/6521/esp32-ethernet-unit-with-poe-compatibility-sanity-check</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 09:02:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6521.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 May 2024 16:40:33 GMT</pubDate><ttl>60</ttl></channel></rss>
