<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stack Fire does not boot after flashing UI Flow 2.0.6.]]></title><description><![CDATA[<p dir="auto">Hello! I am trying to flash UI Flow 2 onto my M5Stack Fire with M5Burner. The flash went successfully. However, the screen does not come on after several tries, although the "zzzz" noise can be heard when pressing the power button. Here are the logs from the serial monitor:</p>
<pre><code class="language-[FROM">ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:4912
load:0x40078000,len:15532
load:0x40080400,len:3696
entry 0x400805e0
       _  __ _
 _   _(_)/ _| | _____      __
| | | | | |_| |/ _ \ \ /\ / /
| |_| | |  _| | (_) \ V  V /
 \__,_|_|_| |_|\___/ \_/\_/  2.0.6
[0;31mE (485) spi: SPI3 already claimed by psram.[0m
[0;31mE (485) spi: spi_bus_initialize(772): host_id already in use[0m
[0;31mE (485) spi_master: spi_master_init_driver(204): host_id not initialized[0m
[0;31mE (494) spi: SPI3 already claimed by psram.[0m
[0;31mE (497) spi: spi_bus_initialize(772): host_id already in use[0m
[0;31mE (503) spi_master: spi_master_init_driver(204): host_id not initialized[0m
[0;31mE (524) spi: SPI3 already claimed by psram.[0m
[0;31mE (524) spi: spi_bus_initialize(772): host_id already in use[0m
[0;31mE (524) spi_master: spi_master_init_driver(204): host_id not initialized[0m
[0;31mE (556) spi: SPI3 already claimed by psram.[0m
[0;31mE (556) spi: spi_bus_initialize(772): host_id already in use[0m
[0;31mE (556) spi_master: spi_master_init_driver(204): host_id not initialized[0m
[0;31mE (587) spi: SPI3 already claimed by psram.[0m
[0;31mE (587) spi: spi_bus_initialize(772): host_id already in use[0m
[0;31mE (587) spi_master: spi_master_init_driver(204): host_id not initialized[0m
E (16273) wifi:Association refused temporarily, comeback time 4294967266 (TUs) too long, max allowed 5000 (TUs)
<p dir="auto">How can I get UI Flow 2 Running on the M5 Stack Fire?</p>
]]></description><link>https://community.m5stack.com/topic/6509/m5-stack-fire-does-not-boot-after-flashing-ui-flow-2-0-6</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 18:39:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6509.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 May 2024 03:34:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stack Fire does not boot after flashing UI Flow 2.0.6. on Sun, 26 May 2024 13:27:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pawinchan" aria-label="Profile: pawinchan">@<bdi>pawinchan</bdi></a> After erasing and then burning (that looks like the correct version)<br />
Once UIFLow say complete hard resetting, wait for a while and then press the fires power/reset button</p>
]]></description><link>https://community.m5stack.com/post/25409</link><guid isPermaLink="true">https://community.m5stack.com/post/25409</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 26 May 2024 13:27:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stack Fire does not boot after flashing UI Flow 2.0.6. on Sun, 26 May 2024 11:23:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
<p dir="auto">Hi, Thanks a lot for your reply.</p>
<p dir="auto">I previously have erased and flashed this one to the M5Fire (in screenshot below). <img src="/assets/uploads/files/1716722127418-screenshot-from-2024-05-26-18-14-19.png" alt="Screenshot from 2024-05-26 18-14-19.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Which version should I go with instead?</p>
]]></description><link>https://community.m5stack.com/post/25407</link><guid isPermaLink="true">https://community.m5stack.com/post/25407</guid><dc:creator><![CDATA[pawinchan]]></dc:creator><pubDate>Sun, 26 May 2024 11:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stack Fire does not boot after flashing UI Flow 2.0.6. on Sun, 26 May 2024 07:53:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pawinchan" aria-label="Profile: pawinchan">@<bdi>pawinchan</bdi></a> You need to erase first and use the correct uiflow2 version.</p>
]]></description><link>https://community.m5stack.com/post/25404</link><guid isPermaLink="true">https://community.m5stack.com/post/25404</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 26 May 2024 07:53:59 GMT</pubDate></item></channel></rss>
