<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stickC Plus 2 connecting SD card Module not working]]></title><description><![CDATA[<p dir="auto">I'm trying to run NEMO or Marauder using an SD card module at 3.3V made specifically for the ESP32 but even tho i followed the right wiring (Displayed below) Neither of them seem to be able to initialise my SD card.</p>
<p dir="auto">Wiring:<br />
M5 --&gt; SD<br />
GND --&gt; GND<br />
3.3v --&gt; 3.3v<br />
G0 --&gt; CLK<br />
G26 --&gt; MISO<br />
G32 --&gt; MOSI<br />
None --&gt; CS</p>
<p dir="auto">(Wiring found in <a href="https://community.m5stack.com/topic/5290/my-m5stickc-plus-can-t-read-micro-sd/3">https://community.m5stack.com/topic/5290/my-m5stickc-plus-can-t-read-micro-sd/3</a>)</p>
<p dir="auto">Does somebody know what the issue might be?</p>
]]></description><link>https://community.m5stack.com/topic/6467/m5stickc-plus-2-connecting-sd-card-module-not-working</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 04:28:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6467.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 May 2024 17:17:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stickC Plus 2 connecting SD card Module not working on Fri, 01 Nov 2024 01:15:50 GMT]]></title><description><![CDATA[<p dir="auto">Here is how I made it work:</p>
<li>CS Connects also to GND in M5.</li>
<li>Some Card adapters requires 5V to work (bigger ones)</li>
<li>Card must be formatted as FAT32</li>
<li>SD card capacity &lt;=32G</li>
]]></description><link>https://community.m5stack.com/post/26912</link><guid isPermaLink="true">https://community.m5stack.com/post/26912</guid><dc:creator><![CDATA[roddpap]]></dc:creator><pubDate>Fri, 01 Nov 2024 01:15:50 GMT</pubDate></item><item><title><![CDATA[Reply to M5stickC Plus 2 connecting SD card Module not working on Wed, 15 May 2024 09:54:40 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://forum.m5stack.com/topic/1002/how-to-connect-sd-card-to-m5stickc" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/1002/how-to-connect-sd-card-to-m5stickc</a></p>
]]></description><link>https://community.m5stack.com/post/25249</link><guid isPermaLink="true">https://community.m5stack.com/post/25249</guid><dc:creator><![CDATA[flypeek]]></dc:creator><pubDate>Wed, 15 May 2024 09:54:40 GMT</pubDate></item><item><title><![CDATA[Reply to M5stickC Plus 2 connecting SD card Module not working on Tue, 14 May 2024 17:36:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wh1t3_01l" aria-label="Profile: wh1t3_01l">@<bdi>wh1t3_01l</bdi></a> CS must be connected somewhere. I don't know the answer, but I know that without CS you can't have the SD card breakoutboard working.</p>
]]></description><link>https://community.m5stack.com/post/25234</link><guid isPermaLink="true">https://community.m5stack.com/post/25234</guid><dc:creator><![CDATA[LEFTIPAN]]></dc:creator><pubDate>Tue, 14 May 2024 17:36:46 GMT</pubDate></item></channel></rss>
