<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TimerCam - &quot;not found image data&quot;]]></title><description><![CDATA[<p dir="auto">Brand new ESP32 PSRAM Timer Camera X (OV3660).  Serial output seems to indicate the picture was uploaded (below), but when I access the URL it says "{"error_msg":"not found image data"}"</p>
<p dir="auto">Note: for some reason the token changes each time I get the token from m5burner (Windows).  Doesn't seem to matter whether I get the token before or after burning.</p>
<p dir="auto">Capturing image...<br />
Posting image to server...success!<br />
-- Image posted to url: <a href="http://api.m5stack.com:5003/timer-cam/image?tok=" target="_blank" rel="noopener noreferrer nofollow ugc">http://api.m5stack.com:5003/timer-cam/image?tok=</a><br />
-- Please add your token at the end of the url<br />
-- You can get your token in M5Burner</p>
]]></description><link>https://community.m5stack.com/topic/6436/timercam-not-found-image-data</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 12:16:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6436.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 May 2024 22:02:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TimerCam - &quot;not found image data&quot; on Sun, 25 Aug 2024 11:15:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/147548">@dhellellerstedt</a><br />
The reason is simple: The images get uploaded, but not to <a href="http://api.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">api.m5stack.com</a> but to 120.77.157.90 (Aliyun/Alibaba Cloud). Simply use that IP and you will get your images. Of course that raises the question why there is this missmatch. Maybe the Firmware-Images in M5Burner got mixed up or some other reason...</p>
<p dir="auto">Regarding the Tokens: They change each time because only the forst 12 chars are relevant.</p>
]]></description><link>https://community.m5stack.com/post/26222</link><guid isPermaLink="true">https://community.m5stack.com/post/26222</guid><dc:creator><![CDATA[Pissflitschki]]></dc:creator><pubDate>Sun, 25 Aug 2024 11:15:47 GMT</pubDate></item><item><title><![CDATA[Reply to TimerCam - &quot;not found image data&quot; on Sun, 25 Aug 2024 01:28:28 GMT]]></title><description><![CDATA[<p dir="auto">I have the same issue. image says it was successfully posted, but when I go to the URL with the token I just get this:</p>
<p dir="auto">{<br />
"error_msg": "not found image data"<br />
]]></description><link>https://community.m5stack.com/post/26219</link><guid isPermaLink="true">https://community.m5stack.com/post/26219</guid><dc:creator><![CDATA[dhellellerstedt]]></dc:creator><pubDate>Sun, 25 Aug 2024 01:28:28 GMT</pubDate></item></channel></rss>
