<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Re-Burn original firmware on M5Paper]]></title><description><![CDATA[<p dir="auto">Greetings to all. A question from an enthusiastic newcomer: how do I reinstall the original (factory) firmware on my M5Paper? Thanks in advance! (I'm also very happy working with the CompuCard!)</p>
<p dir="auto">All the best,</p>
<p dir="auto">Michel Morin<br />
Montreal</p>
]]></description><link>https://community.m5stack.com/topic/6431/re-burn-original-firmware-on-m5paper</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 23:29:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6431.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 May 2024 02:58:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Re-Burn original firmware on M5Paper on Sun, 07 Jul 2024 10:41:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks for your reply. Yes I did erased the flash. Any other ideas??</p>
]]></description><link>https://community.m5stack.com/post/25774</link><guid isPermaLink="true">https://community.m5stack.com/post/25774</guid><dc:creator><![CDATA[turgu]]></dc:creator><pubDate>Sun, 07 Jul 2024 10:41:12 GMT</pubDate></item><item><title><![CDATA[Reply to Re-Burn original firmware on M5Paper on Sun, 07 Jul 2024 06:37:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/turgu" aria-label="Profile: turgu">@<bdi>turgu</bdi></a> did you erase the old firmware off the M5Paper before burning the new firmware?</p>
]]></description><link>https://community.m5stack.com/post/25772</link><guid isPermaLink="true">https://community.m5stack.com/post/25772</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 07 Jul 2024 06:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to Re-Burn original firmware on M5Paper on Sat, 06 Jul 2024 20:18:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks for the information. I was able to install it with the M5Burner, but can't get it to start. Tried to remove the usb cable, reseted the device with the back pin and turned it on with the push button on the side, nothing happened.</p>
]]></description><link>https://community.m5stack.com/post/25769</link><guid isPermaLink="true">https://community.m5stack.com/post/25769</guid><dc:creator><![CDATA[turgu]]></dc:creator><pubDate>Sat, 06 Jul 2024 20:18:42 GMT</pubDate></item><item><title><![CDATA[Reply to Re-Burn original firmware on M5Paper on Sat, 06 Jul 2024 19:57:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/turgu" aria-label="Profile: turgu">@<bdi>turgu</bdi></a> Factory test or the UIFlows is the original firmware.</p>
]]></description><link>https://community.m5stack.com/post/25768</link><guid isPermaLink="true">https://community.m5stack.com/post/25768</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 06 Jul 2024 19:57:45 GMT</pubDate></item><item><title><![CDATA[Reply to Re-Burn original firmware on M5Paper on Sat, 06 Jul 2024 18:13:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I'm on Linux using the M5Burner, can't see the original factory firmware. Here are the entries: UIFlow2, UIFlow, FactoryTest, Calculator, WeatherStation, ToDo, OnlineImage.</p>
]]></description><link>https://community.m5stack.com/post/25767</link><guid isPermaLink="true">https://community.m5stack.com/post/25767</guid><dc:creator><![CDATA[turgu]]></dc:creator><pubDate>Sat, 06 Jul 2024 18:13:36 GMT</pubDate></item><item><title><![CDATA[Reply to Re-Burn original firmware on M5Paper on Tue, 07 May 2024 12:59:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmorin" aria-label="Profile: mmorin">@<bdi>mmorin</bdi></a> you use M5Burner and the factory firmware should be in there</p>
]]></description><link>https://community.m5stack.com/post/25090</link><guid isPermaLink="true">https://community.m5stack.com/post/25090</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 07 May 2024 12:59:39 GMT</pubDate></item></channel></rss>
