<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stamp Cs3, USB powered Over-voltage warning]]></title><description><![CDATA[<p dir="auto">Hello,<br />
As the title explains, M5Stamp Cs3 powered by USB from my laptop.<br />
I noticed that the device is very hot.<br />
I get this warning:<br />
13:23:24.460 -&gt; OVER-VOLTAGE WARNNING<br />
13:23:24.460 -&gt; OVER-VOLTAGE POWER DOWN</p>
<p dir="auto">Suggestions how to deal with this?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/6235/m5stamp-cs3-usb-powered-over-voltage-warning</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Mar 2026 11:35:50 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6235.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Mar 2024 12:28:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stamp Cs3, USB powered Over-voltage warning on Thu, 21 Mar 2024 06:59:02 GMT]]></title><description><![CDATA[<p dir="auto">In this testing environment I wired it to the 3.3 volt output of the Stamp. Not the best solution, ha ha, given the power the SIM7080 module needs. I am now converting it to powering the SIM7080 module with separate 5 volt line.<br />
That should do the trick.</p>
]]></description><link>https://community.m5stack.com/post/24486</link><guid isPermaLink="true">https://community.m5stack.com/post/24486</guid><dc:creator><![CDATA[HappyUser]]></dc:creator><pubDate>Thu, 21 Mar 2024 06:59:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stamp Cs3, USB powered Over-voltage warning on Wed, 20 Mar 2024 21:58:23 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7741">@HappyUser</a></p>
<p dir="auto">according to the <a href="https://docs.m5stack.com/en/stamp/stamp_catm" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> the Stamp CatM has its own DC/DC converter from 5 V to 3.3 V so it should not draw any current from the 3.3 V output of the M5StampC3.</p>
<p dir="auto">How exactly did you wire up the two?</p>
]]></description><link>https://community.m5stack.com/post/24482</link><guid isPermaLink="true">https://community.m5stack.com/post/24482</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 20 Mar 2024 21:58:23 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stamp Cs3, USB powered Over-voltage warning on Wed, 20 Mar 2024 21:07:05 GMT]]></title><description><![CDATA[<p dir="auto">Thanks,<br />
more specific, indeed Stamp C3. And maybe the connected M5Stamp SIM7080C module draws a to high current from the 3.3 volt output on the Stamp C3.  I am going t change that anyways, I am just testing.</p>
]]></description><link>https://community.m5stack.com/post/24481</link><guid isPermaLink="true">https://community.m5stack.com/post/24481</guid><dc:creator><![CDATA[HappyUser]]></dc:creator><pubDate>Wed, 20 Mar 2024 21:07:05 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stamp Cs3, USB powered Over-voltage warning on Wed, 20 Mar 2024 15:31:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7741">@happyuser</a> What do you mean by M5Stamp Cs3? is it Stamp C3 or Stamp S3?<br />
If it is 5V USB powered then it must be the load that it drives that is overheating the body.<br />
Could you be more specific?</p>
<p dir="auto">Cheers</p>
]]></description><link>https://community.m5stack.com/post/24467</link><guid isPermaLink="true">https://community.m5stack.com/post/24467</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 20 Mar 2024 15:31:01 GMT</pubDate></item></channel></rss>
