<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IP5306 automatic standby]]></title><description><![CDATA[<p dir="auto">I was thinkig to use M5Stack for battery powered solution with low consuption. I encountered the problem with IP5306: At low power consuption below 45 mA (it's enough to turn off the LCD LED and turn ESP32 in modem-sleep) the VOUT = VCC_5V of ISP5306 is disconnected after 32 seconds and therefore ESP32 is not powered. Do you have any solution how to teach the IP5306 do not switch to standby automaticaly? It's a shame that the IP5306_I2C has not been used (controlled over I2C).</p>
]]></description><link>https://community.m5stack.com/topic/62/ip5306-automatic-standby</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 20:28:43 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/62.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Dec 2017 20:15:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IP5306 automatic standby on Tue, 21 Nov 2023 19:03:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/505">@vshymanskyy</a> please, could you send schematic of IP56306 I2C connection? I try to connect to my (which should have I2C) - but she doesn't reply. I use external microcontroller with external supply. Also I connect SCL to 2nd and SDA to 3st pin pin of IP5306. IP5306 powered from li-ion battery.</p>
]]></description><link>https://community.m5stack.com/post/22847</link><guid isPermaLink="true">https://community.m5stack.com/post/22847</guid><dc:creator><![CDATA[forelnyr]]></dc:creator><pubDate>Tue, 21 Nov 2023 19:03:40 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Mon, 17 Dec 2018 05:09:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/505">@vshymanskyy</a> Did you scann old chip (IP5306) or new version (IP5306_I2C). Can it be possible, that old version can I2C too?</p>
]]></description><link>https://community.m5stack.com/post/2204</link><guid isPermaLink="true">https://community.m5stack.com/post/2204</guid><dc:creator><![CDATA[elecvoice]]></dc:creator><pubDate>Mon, 17 Dec 2018 05:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Thu, 13 Dec 2018 15:01:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/505">@vshymanskyy</a><br />
IP5306 <a href="https://yadi.sk/i/dRp0HTF4oPCo2g" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/i/dRp0HTF4oPCo2g</a></p>
<p dir="auto">Same thing for IP5209 IP5109 IP5207 IP5108<br />
<a href="https://yadi.sk/i/oNhqTei36jFwSg" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/i/oNhqTei36jFwSg</a></p>
]]></description><link>https://community.m5stack.com/post/2186</link><guid isPermaLink="true">https://community.m5stack.com/post/2186</guid><dc:creator><![CDATA[elecvoice]]></dc:creator><pubDate>Thu, 13 Dec 2018 15:01:17 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Sun, 15 Jul 2018 14:36:20 GMT]]></title><description><![CDATA[<p dir="auto">Who is interested in the IP5108 solution, so look at the implementation in the section PROJECTS:<br />
<a href="http://forum.m5stack.com/topic/259/m5-power-bank-with-ip5108" target="_blank" rel="noopener noreferrer nofollow ugc">M5 Power Bank with IP5108</a></p>
]]></description><link>https://community.m5stack.com/post/1270</link><guid isPermaLink="true">https://community.m5stack.com/post/1270</guid><dc:creator><![CDATA[JiKuch]]></dc:creator><pubDate>Sun, 15 Jul 2018 14:36:20 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Fri, 06 Jul 2018 13:00:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/82">@JiKuch</a> , <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/55">@loboris</a>, <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a>, @JimiT</p>
<p dir="auto">Does anyone have a list of all I2C registers of IP5306_I2C (preferably, in english)?<br />
Also, what is the I2C address of this chip? I tried running I2C scanner and I get:</p>
<pre><code>  0x68 =&gt; MPU9250
  0x0E =&gt; MAG3110
  0x75 =&gt; IP5306 ???
<p dir="auto">Correct me if I'm wrong.</p>
]]></description><link>https://community.m5stack.com/post/1239</link><guid isPermaLink="true">https://community.m5stack.com/post/1239</guid><dc:creator><![CDATA[vshymanskyy]]></dc:creator><pubDate>Fri, 06 Jul 2018 13:00:01 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Thu, 22 Mar 2018 19:42:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> 在 <a href="/post/624">IP5306 automatic standby</a> 中说：</p>
<p dir="auto">hi there, i had ordered 4k pcs ip5306_i2C, and change the newest board for this, so the new model can close this function.</p>
<p dir="auto">Great news, but make shure that the new board is degned in a way that the total power consumption of all the additional circuitry (except ESP32 itself) can be reduced to <strong>at least &lt;100 uA</strong>, otherwise it wont be very useful.</p>
]]></description><link>https://community.m5stack.com/post/627</link><guid isPermaLink="true">https://community.m5stack.com/post/627</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Thu, 22 Mar 2018 19:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Thu, 22 Mar 2018 10:05:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> - very good news!</p>
<p dir="auto">P.S. please also check the quality of connectors,  especially female (on master board),<br />
maybe only my m5stack has such a problem but from the beginning of use, various pins have a contact problem<br />
with bottom plates(I check different: ioExtension/proto board/battery board).<br />
Evidently male pins from bottom plates do not have good contact with female connector on base plate, I do not check all contacts but have problem with accu pin, adc35 pin, adc36 pin.<br />
<em>it's very annoying and spoils the positive impression from the module</em><br />
<em>when you can not read the input status and wonder what is wrong in the code</em><br />
<em>and it's not the fault of the code but the lack of contact</em></p>
<p dir="auto">P.S.P.S please also vote for this PR: <a href="https://github.com/espressif/arduino-esp32/pull/1242" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/espressif/arduino-esp32/pull/1242</a><br />
because current version of board.txt do not include proper pins_arduino.h variant for m5stack and for e.g. ADC1 or ADC2 are unknown when compile</p>
]]></description><link>https://community.m5stack.com/post/625</link><guid isPermaLink="true">https://community.m5stack.com/post/625</guid><dc:creator><![CDATA[reaper7]]></dc:creator><pubDate>Thu, 22 Mar 2018 10:05:07 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Thu, 22 Mar 2018 07:24:04 GMT]]></title><description><![CDATA[<p dir="auto">hi there, i had ordered 4k pcs ip5306_i2C, and change the newest board for this, so the new model can close this function.</p>
]]></description><link>https://community.m5stack.com/post/624</link><guid isPermaLink="true">https://community.m5stack.com/post/624</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 22 Mar 2018 07:24:04 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Wed, 21 Mar 2018 09:52:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/185">@pelocks</a> 在 <a href="/post/621">IP5306 automatic standby</a> 中说：</p>
<p dir="auto">Are 2018 models came with the same IP5306 stand by setup?</p>
<p dir="auto">Could it be customized for big orders?</p>
<p dir="auto">Thanks guys</p>
<p dir="auto">2018 models have the same problem with IP5306 standby.</p>
<p dir="auto">You can't get very low power consumption in deepsleep with M5Stack anyway, so waking up every 30 seconds, checking the elapsed time and going to deepsleep immediately if needed won't make much difference.</p>
]]></description><link>https://community.m5stack.com/post/622</link><guid isPermaLink="true">https://community.m5stack.com/post/622</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Wed, 21 Mar 2018 09:52:49 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Tue, 20 Mar 2018 11:52:21 GMT]]></title><description><![CDATA[<p dir="auto">Are 2018 models came with the same IP5306 stand by setup?</p>
]]></description><link>https://community.m5stack.com/post/621</link><guid isPermaLink="true">https://community.m5stack.com/post/621</guid><dc:creator><![CDATA[Pelocks]]></dc:creator><pubDate>Tue, 20 Mar 2018 11:52:21 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Mon, 05 Mar 2018 13:09:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Any ideas to avoid automatic standby?<br />
i am working with deepsleep and it wont wakeup above 30seconds setup.</p>
<p dir="auto">Thanks!!!</p>
]]></description><link>https://community.m5stack.com/post/510</link><guid isPermaLink="true">https://community.m5stack.com/post/510</guid><dc:creator><![CDATA[Pelocks]]></dc:creator><pubDate>Mon, 05 Mar 2018 13:09:38 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Mon, 05 Mar 2018 11:47:15 GMT]]></title><description><![CDATA[<p dir="auto">According to the data sheet (in Chinese language only by the way),<br />
if the load current drops below 45mA during 32 seconds, the IP5306 goes into standby.</p>
<p dir="auto">This is useful information for making some sort of heartbeat circuit to keep the IP5306 from going into standby.</p>
]]></description><link>https://community.m5stack.com/post/508</link><guid isPermaLink="true">https://community.m5stack.com/post/508</guid><dc:creator><![CDATA[on4aa]]></dc:creator><pubDate>Mon, 05 Mar 2018 11:47:15 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Mon, 05 Mar 2018 17:17:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/82">@jikuch</a></p>
<p dir="auto">Hi Ji,</p>
<p dir="auto">Thanks for the update. Nice project. I will keep an eye on the projects section....</p>
<p dir="auto">It seems likely the M5Stack guys would want to sort this out given that low power is one of the attractions of the ESP32, so most likely they are still working on it.</p>
<p dir="auto">From their comment and perhaps your experience also, it may be that availability of the IP5306_I2C was the problem.</p>
<p dir="auto">Perhaps they could  use the IP5108 in future (?).</p>
]]></description><link>https://community.m5stack.com/post/211</link><guid isPermaLink="true">https://community.m5stack.com/post/211</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Mon, 05 Mar 2018 17:17:49 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Sat, 20 Jan 2018 14:20:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi JimiT.</p>
<p dir="auto">Unfortunately, I did not get IP5306. This version 1.0 of M5Stack POWER BANK will not be implemented. I'm creating version 2.0 with IP5108, which is available:</p>
<p dir="auto"><img src="/assets/uploads/files/1516457946589-b7aa6a0d-f4eb-4a7c-9ad2-a962f0887a4c-image-resized.png" alt="0_1516457944820_b7aa6a0d-f4eb-4a7c-9ad2-a962f0887a4c-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">IP53108 can be purchased here, for example:<br />
<a href="https://www.aliexpress.com/store/1816136?spm=2114.10010108.100005.2.7cb76625aejUQV" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/store/1816136?spm=2114.10010108.100005.2.7cb76625aejUQV</a><br />
LiPol 103450 with capacity 2.500mAh here, for example:<br />
<a href="https://www.aliexpress.com/store/715509?spm=2114.10010108.100005.2.536685a84W2wpg" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/store/715509?spm=2114.10010108.100005.2.536685a84W2wpg</a></p>
<p dir="auto">If I create M5Stack POWER BANK, I will continue in the section projects.<br />
This FAQS contains problem with the IP5306 and it is a pity that the M5Stack team does not respond and does not inform: the last delivery, which I received, contained the M5Stack in black with IP5306_CK, which does not have an automatic standby! Hurray!</p>
]]></description><link>https://community.m5stack.com/post/210</link><guid isPermaLink="true">https://community.m5stack.com/post/210</guid><dc:creator><![CDATA[JiKuch]]></dc:creator><pubDate>Sat, 20 Jan 2018 14:20:43 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Tue, 16 Jan 2018 12:07:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/82">@jikuch</a></p>
<p dir="auto">Hi Ji,<br />
just wondering if you were able to source the  IP5306_I2C and if you are still going ahead with this build ? Nice work BTW.</p>
]]></description><link>https://community.m5stack.com/post/196</link><guid isPermaLink="true">https://community.m5stack.com/post/196</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Tue, 16 Jan 2018 12:07:32 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Mon, 08 Jan 2018 11:33:39 GMT]]></title><description><![CDATA[<p dir="auto">hello , i had asked them, but the i2c verison is hard to buy.</p>
]]></description><link>https://community.m5stack.com/post/155</link><guid isPermaLink="true">https://community.m5stack.com/post/155</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 08 Jan 2018 11:33:39 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Mon, 08 Jan 2018 09:16:20 GMT]]></title><description><![CDATA[<p dir="auto">To solve the problem with IP5306, I decided to implement the BATTERY MODULE with IP5306_I2C as follows:<br />
<img src="/assets/uploads/files/1515402963959-97994060-2969-49dc-ad9c-7b3887d95a17-image-resized.png" alt="0_1515402962456_97994060-2969-49dc-ad9c-7b3887d95a17-image.png" class=" img-fluid img-markdown" /><br />
The implementation will be as soon as I can buy IP5306_I2C.<br />
I welcome any comments and suggestions.</p>
]]></description><link>https://community.m5stack.com/post/154</link><guid isPermaLink="true">https://community.m5stack.com/post/154</guid><dc:creator><![CDATA[JiKuch]]></dc:creator><pubDate>Mon, 08 Jan 2018 09:16:20 GMT</pubDate></item><item><title><![CDATA[Reply to IP5306 automatic standby on Sat, 06 Jan 2018 19:03:37 GMT]]></title><description><![CDATA[<p dir="auto">I get the answer from the manufacturer of IP5306 (Injoinic Tech):</p>
<li>You can use IP5306_CK，this version always output 5V.</li>
<li>I2C function only apply to IP5306_I2C custom design. you can  order samples use the name: IP5306_I2C.</li>
<li>Accessory is the I2C register document of IP5306, you can use IP5306_I2C, then modify IP5306's register(reg0x00[1]=1) to make IP5306 always output 5V.</li>
<p dir="auto">英集芯科技  Injoinic Tech<br />
陈  卫<br />
公司网址：<a href="http://www.injoinic.com" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.injoinic.com</a><br />
邮箱：chenwei086@injoinic.com<br />
QQ :  248371522<br />
地址：广东省珠海市唐家湾高新区南方软件园A1栋8楼</p>
]]></description><link>https://community.m5stack.com/post/150</link><guid isPermaLink="true">https://community.m5stack.com/post/150</guid><dc:creator><![CDATA[JiKuch]]></dc:creator><pubDate>Sat, 06 Jan 2018 19:03:37 GMT</pubDate></item></channel></rss>
