<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom Echo broken?]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I came to the Atom Echo by <a href="https://www.home-assistant.io/voice_control/thirteen-usd-voice-remote/" target="_blank" rel="noopener noreferrer nofollow ugc">$13 voice assistant for Home Assistant</a> article. It was working, just by simple installing.</p>
<p dir="auto">I put the Atom Echo to an external 5V wall plug charger and I realized that actually the LEDs did not turn on. I was trying to reprogram it, but it stays in the ESPhome "Connecting" loop and fails by timeout. Same thing on the commandline getting the chip_id by esptool fails</p>
<pre><code>❯ esptool.py --port /dev/ttyUSB0 chip_id
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to Espressif device: Timed out waiting for packet header
<p dir="auto">Same thing with the updated esptool version 4.7.</p>
<p dir="auto">I tried several button combinations to enter the programming mode, is there any trick? The echo has a Reset button and the larger top button which is from my understand more for application use.</p>
]]></description><link>https://community.m5stack.com/topic/6034/atom-echo-broken</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 14:34:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6034.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Jan 2024 22:43:59 GMT</pubDate><ttl>60</ttl></channel></rss>
