<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom Lite only powers via USB-C but not 5V from pin header]]></title><description><![CDATA[<p dir="auto">I got the Atom RS485 kit and my RS485 endpoint provides +12V DC on the orange header which I want to use to power the Atom.</p>
<p dir="auto">I measure +13V at the DC12V input pin. Without the Atom Lite connected, I measure 4.84V at the 5V pin header on the base.</p>
<p dir="auto">However, when I connect both, I cannot reach the Atom. Note that even with the Atom Lite in place, I still measure a fixed +13V at the DC12V input pin, hence I do not believe the source is unable to supply sufficient current (otherwise the voltage would drop).</p>
<p dir="auto">However, if I power the Atom Lite via USB-C instead, everything works.</p>
<p dir="auto">I thought already the base is broken, hence I ordered an additional base but unfortunately same.</p>
<p dir="auto">Why does the Atom Lite fail to power from the 5V from the pin header?</p>
]]></description><link>https://community.m5stack.com/topic/5963/atom-lite-only-powers-via-usb-c-but-not-5v-from-pin-header</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 09:00:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5963.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Jan 2024 20:03:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atom Lite only powers via USB-C but not 5V from pin header on Wed, 10 Jan 2024 08:33:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/73914">@expjwt</a></p>
<p dir="auto">according to the <a href="http://docs.m5stack.com/en/atom/atomic485" target="_blank" rel="noopener noreferrer nofollow ugc">description</a> the M5Atom can be powered from the 12 V.</p>
<p dir="auto"><em>A DC/DC voltage regulator chip is integrated in the ATOM RS-485, which can directly convert the 12V voltage of RS485 to 5V to supply power for M5ATOM, avoiding the trouble of using a separate power supply.</em></p>
<p dir="auto">BTW: The 5 V on the header pin is connected to the 5 V on the Groove port. What voltage do you measure between 5 V and GND on the Groove port?</p>
]]></description><link>https://community.m5stack.com/post/23293</link><guid isPermaLink="true">https://community.m5stack.com/post/23293</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 10 Jan 2024 08:33:44 GMT</pubDate></item></channel></rss>
