<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stepmotor Driver Module v1.1 (HR8825) M5STACK SKU: M039-V11 Question]]></title><description><![CDATA[<p dir="auto">Hi with Stepmotor Driver Module v1.1  I need to drive my stepper with the command in UI flow that's step/direction number /of steps but I can't find this when I load this module .</p>
<p dir="auto">This is like what I required but this command is from another module.</p>
<p dir="auto">![alt text](<img src="/assets/uploads/files/1704802590480-458d3289-0d89-4aab-b41f-0cfb6ac88871-image.png" alt="0_1704802589314_458d3289-0d89-4aab-b41f-0cfb6ac88871-image.png" class=" img-fluid img-markdown" /> image url)</p>
]]></description><link>https://community.m5stack.com/topic/5962/stepmotor-driver-module-v1-1-hr8825-m5stack-sku-m039-v11-question</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 13:29:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5962.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Jan 2024 12:17:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stepmotor Driver Module v1.1 (HR8825) M5STACK SKU: M039-V11 Question on Wed, 24 Jan 2024 09:49:20 GMT]]></title><description><![CDATA[<p dir="auto">I confirmed that the sample code works. However, the micro step does not work well. The step width is the same even if I change the settings. Is there a special setup procedure?</p>
]]></description><link>https://community.m5stack.com/post/23451</link><guid isPermaLink="true">https://community.m5stack.com/post/23451</guid><dc:creator><![CDATA[m5stackfun]]></dc:creator><pubDate>Wed, 24 Jan 2024 09:49:20 GMT</pubDate></item><item><title><![CDATA[Reply to Stepmotor Driver Module v1.1 (HR8825) M5STACK SKU: M039-V11 Question on Fri, 12 Jan 2024 01:24:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/ashimotok0" aria-label="Profile: AshimotoK0">@<bdi>AshimotoK0</bdi></a>, please try this example code.  x, y and z motors can be controlled</p>
<p dir="auto"><img src="/assets/uploads/files/1705022399271-f0ef145e-1673-421a-aba9-7bd0101fc587-image-resized.png" alt="0_1705022395564_f0ef145e-1673-421a-aba9-7bd0101fc587-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/23312</link><guid isPermaLink="true">https://community.m5stack.com/post/23312</guid><dc:creator><![CDATA[pandian.nano]]></dc:creator><pubDate>Fri, 12 Jan 2024 01:24:56 GMT</pubDate></item><item><title><![CDATA[Reply to Stepmotor Driver Module v1.1 (HR8825) M5STACK SKU: M039-V11 Question on Thu, 11 Jan 2024 23:00:56 GMT]]></title><description><![CDATA[<p dir="auto">@pandian-nano  Thanks .. with the M039-V11 is there a command in UIflow to Step a certain number of pulses ? As in the image I posted. I only need to use one axis (i.e only controlling one stepper motor)</p>
]]></description><link>https://community.m5stack.com/post/23311</link><guid isPermaLink="true">https://community.m5stack.com/post/23311</guid><dc:creator><![CDATA[AshimotoK0]]></dc:creator><pubDate>Thu, 11 Jan 2024 23:00:56 GMT</pubDate></item><item><title><![CDATA[Reply to Stepmotor Driver Module v1.1 (HR8825) M5STACK SKU: M039-V11 Question on Wed, 10 Jan 2024 01:57:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/ashimotok0" aria-label="Profile: AshimotoK0">@<bdi>AshimotoK0</bdi></a><br />
These two modules are different, stepmotor[sku m012 &amp; m035] modules support g-code command and stepmotor driver[SKU:M039] does not support g-code command</p>
]]></description><link>https://community.m5stack.com/post/23289</link><guid isPermaLink="true">https://community.m5stack.com/post/23289</guid><dc:creator><![CDATA[pandian.nano]]></dc:creator><pubDate>Wed, 10 Jan 2024 01:57:19 GMT</pubDate></item></channel></rss>
