<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5paper USB mode]]></title><description><![CDATA[<p dir="auto">Hey there,<br />
How can I turn my m5paper to usb Mode. I tried to burn both uiflow and factory test. On both thonny tells the device is busy.</p>
]]></description><link>https://community.m5stack.com/topic/5921/m5paper-usb-mode</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Mar 2026 08:26:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5921.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Dec 2023 20:12:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5paper USB mode on Sat, 30 Dec 2023 09:18:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/42859">@alwa123</a> Yes, you use M5Burner to Upload the latest UIFlow Firmware to the M5Paper, Open Thonny, set the port to the M5Paper, Se mode to Micropython generic and then connect.</p>
<p dir="auto">Once connected you will need to hit CTRL+C or another combination that will be show in the shell to interrupt the running program and get access to the REPL command.</p>
]]></description><link>https://community.m5stack.com/post/23179</link><guid isPermaLink="true">https://community.m5stack.com/post/23179</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 30 Dec 2023 09:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper USB mode on Sat, 30 Dec 2023 09:02:14 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply, so I can't performe something like that on the m5paper?</p>
<p dir="auto">Thonny with m5stack:<br />
<a href="https://youtu.be/YEQPAK609Uo?si=dlmyWouOBeYbLjrE" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/YEQPAK609Uo?si=dlmyWouOBeYbLjrE</a></p>
]]></description><link>https://community.m5stack.com/post/23177</link><guid isPermaLink="true">https://community.m5stack.com/post/23177</guid><dc:creator><![CDATA[alwa123]]></dc:creator><pubDate>Sat, 30 Dec 2023 09:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper USB mode on Fri, 29 Dec 2023 13:05:49 GMT]]></title><description><![CDATA[<p dir="auto">You use M5 Burner to burn firmware</p>
]]></description><link>https://community.m5stack.com/post/23168</link><guid isPermaLink="true">https://community.m5stack.com/post/23168</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 29 Dec 2023 13:05:49 GMT</pubDate></item></channel></rss>
