<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Atom QR-Code Scanner Factor Reset Broke Device]]></title><description><![CDATA[<p dir="auto">I've been using the QR-Code scanner successfully, and all my code works in the M5 Atom. It's<br />
amazing that that small device can run all the same software as my M5 (minus the display). I have<br />
MQTT and BLE working nicely.</p>
<p dir="auto">Anyway, I have a version that interacts with the QR-Code scanner. My version is based on the ATOMQR_UART_CMD.cpp code. I was trying to get the device to "mute" on startup, and actually had it working for a short time (until the factor reset I'll describe next).</p>
<p dir="auto">Here is my issue:</p>
<li>I scanned the "Factory Reset" QR code from <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/atombase/AtomicQR/AtomicQR_Reader_EN.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">AtomicQR_Reader_EN.pdf</a></li>
<p dir="auto"><strong>Now the device will not work.</strong> This means no lights and no scanning.</p>
<p dir="auto">The M5 Atom still works (MQTT and BLE) but it doesn't QR Scan anymore.</p>
<p dir="auto">QUESTION: is there a way to get the device back working through the arduino download?</p>
<p dir="auto">Help.<br />
thanks.<br />
scott</p>
]]></description><link>https://community.m5stack.com/topic/5880/m5-atom-qr-code-scanner-factor-reset-broke-device</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 10:21:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5880.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Dec 2023 03:17:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Atom QR-Code Scanner Factor Reset Broke Device on Tue, 01 Apr 2025 00:04:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/16054">@konacurrents</a> Note, I have a similar startup issue with the Atom Socket and H-Driver.</p>
<p dir="auto">Anyone know how to stop it starting before I get a change to stop it?</p>
<p dir="auto"><a href="https://community.m5stack.com/topic/7445/m5atom-based-power-turns-on-briefly-before-user-code-runs">https://community.m5stack.com/topic/7445/m5atom-based-power-turns-on-briefly-before-user-code-runs</a></p>
]]></description><link>https://community.m5stack.com/post/28730</link><guid isPermaLink="true">https://community.m5stack.com/post/28730</guid><dc:creator><![CDATA[konacurrents]]></dc:creator><pubDate>Tue, 01 Apr 2025 00:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Atom QR-Code Scanner Factor Reset Broke Device on Thu, 27 Mar 2025 23:56:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/252775">@Scotty42</a> I have used that barcode scanner to configure the QR scanner so will have to re-visit that approach. I have got the sound to go away but forgot how to do that. I have tried code to do that. Unfortunately some of these devices have a pre-state, like when powered up, which makes a sound before I can turn sound off. (Same with H-Driver and Atom Socket I just posted)</p>
<p dir="auto">There is a mode to not accept those barcodes (so an end user cannot change some setting your code didn't want set).</p>
<p dir="auto">Right now I use MQTT/BLE to set what it would scan - and then play that back from a button click. Basically store and re-play later - just like the QR code scanner achieves.</p>
<p dir="auto">For my system, the QR code will invoke messages in my network - to turn on the lights, or feed the dog. I call this a Semantic Marker(R).</p>
<p dir="auto">cheers,<br />
thanks,<br />
scott (also scotty)</p>
]]></description><link>https://community.m5stack.com/post/28696</link><guid isPermaLink="true">https://community.m5stack.com/post/28696</guid><dc:creator><![CDATA[konacurrents]]></dc:creator><pubDate>Thu, 27 Mar 2025 23:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Atom QR-Code Scanner Factor Reset Broke Device on Thu, 27 Mar 2025 19:41:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/16054">@konacurrents</a> See here: <a href="https://community.m5stack.com/post/28583">https://community.m5stack.com/post/28583</a> . Maybe the suggested solution would work for you as well ? I couldn't test it but will do so in the coming days and report back.</p>
]]></description><link>https://community.m5stack.com/post/28694</link><guid isPermaLink="true">https://community.m5stack.com/post/28694</guid><dc:creator><![CDATA[Scotty42]]></dc:creator><pubDate>Thu, 27 Mar 2025 19:41:31 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Atom QR-Code Scanner Factor Reset Broke Device on Mon, 24 Mar 2025 19:27:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/252775">@Scotty42</a> I haven't been using the QR scanner as much especially as I cannot get the startup sound to go away (and it freaks my dogs). But the scanner works.</p>
<p dir="auto">What issues are you having?</p>
<p dir="auto">-scott</p>
]]></description><link>https://community.m5stack.com/post/28635</link><guid isPermaLink="true">https://community.m5stack.com/post/28635</guid><dc:creator><![CDATA[konacurrents]]></dc:creator><pubDate>Mon, 24 Mar 2025 19:27:53 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Atom QR-Code Scanner Factor Reset Broke Device on Thu, 20 Mar 2025 21:08:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/16054">@konacurrents</a><br />
Hi Scott,</p>
<p dir="auto">I ran into the same problem. Did you find a solution?</p>
<p dir="auto">BR // Scotty42</p>
]]></description><link>https://community.m5stack.com/post/28578</link><guid isPermaLink="true">https://community.m5stack.com/post/28578</guid><dc:creator><![CDATA[Scotty42]]></dc:creator><pubDate>Thu, 20 Mar 2025 21:08:23 GMT</pubDate></item></channel></rss>
