<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM S3, How to switch to online programming mode?]]></title><description><![CDATA[<p dir="auto">I am programing ATOM S3 with UIFlow2.<br />
After downloading the program to the ATOM S3, I would like to re-enter Programing mode (internet mode) to rewrite the program from UIFlow.<br />
How can I switch to this programming mode?</p>
]]></description><link>https://community.m5stack.com/topic/5827/atom-s3-how-to-switch-to-online-programming-mode</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 14:42:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5827.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Nov 2023 16:24:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM S3, How to switch to online programming mode? on Sun, 26 Nov 2023 01:14:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/22883">ATOM S3, How to switch to online programming mode?</a>:</p>
<p dir="auto">By pressing the screen on boot<br />
My case, This is to enter programing mode. not come back to App mode.<br />
My version is UIFlow2.0 Alpha28. what version did you success this way?</p>
<p dir="auto">M5Burner to get into app mode<br />
This doesn't work.<br />
I did following step. Please advice if the step is wrong.</p>
<li>Open M5 burner and select ATOM S3.</li>
<li>Connect USB to ATOM S3, hold reset button dew second until internal LED turn on.</li>
<li>Click "Configure" of UIFlow2.0</li>
<li>Change Boot option to "Run <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a> directly"</li>
<li>Click next to burning the setting</li>
<li>once window shows "success", remove USB from Atom S3 and re-connect</li>
<p dir="auto">After this step, the program does not start.<br />
The window is just black screen.<br />
What version of UIFlow are you using?</p>
]]></description><link>https://community.m5stack.com/post/22896</link><guid isPermaLink="true">https://community.m5stack.com/post/22896</guid><dc:creator><![CDATA[Handicraft Record Book]]></dc:creator><pubDate>Sun, 26 Nov 2023 01:14:55 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM S3, How to switch to online programming mode? on Fri, 24 Nov 2023 16:26:58 GMT]]></title><description><![CDATA[<p dir="auto">By pressing the screen on boot or use M5Burner to get into app mode</p>
]]></description><link>https://community.m5stack.com/post/22883</link><guid isPermaLink="true">https://community.m5stack.com/post/22883</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 24 Nov 2023 16:26:58 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM S3, How to switch to online programming mode? on Fri, 24 Nov 2023 16:16:55 GMT]]></title><description><![CDATA[<p dir="auto">I hope last program still remain in the memory.<br />
Do you know how to switching back to app mode?</p>
]]></description><link>https://community.m5stack.com/post/22882</link><guid isPermaLink="true">https://community.m5stack.com/post/22882</guid><dc:creator><![CDATA[Handicraft Record Book]]></dc:creator><pubDate>Fri, 24 Nov 2023 16:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM S3, How to switch to online programming mode? on Wed, 22 Nov 2023 05:57:41 GMT]]></title><description><![CDATA[<p dir="auto">As far as I am aware, the last program should remain in the memory and switching back to app mode should run it again.</p>
]]></description><link>https://community.m5stack.com/post/22856</link><guid isPermaLink="true">https://community.m5stack.com/post/22856</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 22 Nov 2023 05:57:41 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM S3, How to switch to online programming mode? on Mon, 20 Nov 2023 15:16:00 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!<br />
When I <strong>power up with pressing LCD button</strong>, I could enter programing mode.<br />
Also, when the power was turned on again after this (without pressing the LCD button), it was confirmed that the programming mode was continued.<br />
Were the Downloaded programs erased from the ATOM when I switched to programming mode?<br />
I can get back into App mode by downloading again from UIFlow, but is it possible to get back into App mode without doing so?</p>
<p dir="auto">For example, if I accidentally hold down the LCD and connect it to the power supply while using/demonstrating program on ATOM S3, can I return to my program by ATOM itself?, or do I have to write the program again (Need PC)?</p>
]]></description><link>https://community.m5stack.com/post/22831</link><guid isPermaLink="true">https://community.m5stack.com/post/22831</guid><dc:creator><![CDATA[Handicraft Record Book]]></dc:creator><pubDate>Mon, 20 Nov 2023 15:16:00 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM S3, How to switch to online programming mode? on Mon, 20 Nov 2023 09:33:41 GMT]]></title><description><![CDATA[<p dir="auto">There is a button press sequence but the easiest is to use M5Burner and change the configuration to programming mode</p>
]]></description><link>https://community.m5stack.com/post/22827</link><guid isPermaLink="true">https://community.m5stack.com/post/22827</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 20 Nov 2023 09:33:41 GMT</pubDate></item></channel></rss>
