<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I need a try and except block in UI Flow 2.]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I need a try and except block in UI Flow 2.</p>
<p dir="auto">------- example -------<br />
try:<br />
print(x)<br />
except:<br />
print("An exception occurred")</p>
]]></description><link>https://community.m5stack.com/topic/5818/i-need-a-try-and-except-block-in-ui-flow-2</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 21:06:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5818.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Nov 2023 10:17:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I need a try and except block in UI Flow 2. on Tue, 28 Nov 2023 06:41:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jamesarm97" aria-label="Profile: jamesarm97">@<bdi>jamesarm97</bdi></a> Thank you. I had used the try block.</p>
]]></description><link>https://community.m5stack.com/post/22918</link><guid isPermaLink="true">https://community.m5stack.com/post/22918</guid><dc:creator><![CDATA[digiponta]]></dc:creator><pubDate>Tue, 28 Nov 2023 06:41:10 GMT</pubDate></item><item><title><![CDATA[Reply to I need a try and except block in UI Flow 2. on Tue, 21 Nov 2023 19:59:49 GMT]]></title><description><![CDATA[<p dir="auto">This exists in the latest alpha version of UIFLOW2 I am using. Just had to use it because I was getting an exception reading from and I2C device that didnt exist and the program would stop,</p>
]]></description><link>https://community.m5stack.com/post/22852</link><guid isPermaLink="true">https://community.m5stack.com/post/22852</guid><dc:creator><![CDATA[jamesarm97]]></dc:creator><pubDate>Tue, 21 Nov 2023 19:59:49 GMT</pubDate></item></channel></rss>
