<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM Lite esp32-pico-d4 5V tolerant inputs?]]></title><description><![CDATA[<p dir="auto">The ATOM Lite has a 5V output for the GROVE port but the esp32-pico-d4 uC datasheet says the max digitals high level input is VDD+0.3.  The ATOM Lite is powering the ESP32 with 3.3V so that means the max voltage on the i2c SCL &amp; SCA pins would be 3.6V.</p>
<p dir="auto">Why does the ESP32 output 5V on the GROVE port it if can't accept 5V digital inputs.  Do all i2c devices require their own 5V -&gt; 3.3V step down converter then?</p>
]]></description><link>https://community.m5stack.com/topic/5789/atom-lite-esp32-pico-d4-5v-tolerant-inputs</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 09:34:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5789.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Nov 2023 02:11:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM Lite esp32-pico-d4 5V tolerant inputs? on Fri, 10 Nov 2023 12:01:25 GMT]]></title><description><![CDATA[<p dir="auto">All esp’s are like modern controllers are only 3.3V tolerant, the 5v on the grove is for the grove Standered and for sensors that still require 5v.</p>
]]></description><link>https://community.m5stack.com/post/22710</link><guid isPermaLink="true">https://community.m5stack.com/post/22710</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 10 Nov 2023 12:01:25 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM Lite esp32-pico-d4 5V tolerant inputs? on Fri, 10 Nov 2023 09:49:50 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/62789">@LukeS</a></p>
<p dir="auto">yes, that is correct, a step down converter is required.</p>
<p dir="auto">I think the reason behind the decision to have 5 V on the Groove port is to be able to deliver more energy. In the original M5Stack the 5 V are coming directly from USB whereas the 3.3 V comes from the internal regulator which is limited in what amperage it can deliver.</p>
]]></description><link>https://community.m5stack.com/post/22707</link><guid isPermaLink="true">https://community.m5stack.com/post/22707</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 10 Nov 2023 09:49:50 GMT</pubDate></item></channel></rss>
