<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Core2 Connection trouble after upload]]></title><description><![CDATA[<p dir="auto">Hi<br />
I'm new to this great M5Stack.<br />
My Problem exists with USB and WiFi.<br />
After Intial with FW Update i can Download by USB or Wifi. After that the M5Stack boots correct and display the new screen.<br />
Now i change anything on the uiflow and want to download again...no connect anymore.<br />
Also when i rest the Notebook and the M5Stack...no connection again.</p>
<p dir="auto">Now i upload again the Firmware and connect by USB or Wifi, now i can download the changes of the uiflow, but only one time!</p>
<p dir="auto">any hint's for that?<br />
thanks<br />
pat</p>
]]></description><link>https://community.m5stack.com/topic/5725/m5stack-core2-connection-trouble-after-upload</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 04:28:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5725.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Oct 2023 16:25:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Core2 Connection trouble after upload on Mon, 23 Oct 2023 13:06:18 GMT]]></title><description><![CDATA[<p dir="auto">You are writing a program that doesn’t have WiFi setup blocks which is deactivate the WiFi.  If you press reset you should have the option to re connect</p>
]]></description><link>https://community.m5stack.com/post/22560</link><guid isPermaLink="true">https://community.m5stack.com/post/22560</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 23 Oct 2023 13:06:18 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core2 Connection trouble after upload on Mon, 23 Oct 2023 12:47:52 GMT]]></title><description><![CDATA[<p dir="auto">hi<br />
thanks for all the hint's.<br />
i will try...and let you know</p>
]]></description><link>https://community.m5stack.com/post/22559</link><guid isPermaLink="true">https://community.m5stack.com/post/22559</guid><dc:creator><![CDATA[Valbuz]]></dc:creator><pubDate>Mon, 23 Oct 2023 12:47:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core2 Connection trouble after upload on Sat, 21 Oct 2023 18:49:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/59994">@valbuz</a> said in <a href="/post/22533">M5Stack Core2 Connection trouble after upload</a>:</p>
<p dir="auto">After FW Upgrade i see no error and no red textes.</p>
<p dir="auto">On the M5Stack i see a text in red which tell me reboot and then select the correct connection (or else)<br />
After that i can connect by USB or Wifi and download. But only one time!</p>
<p dir="auto">If you reopen M5Burner, and click on configure, you can change it from app to UIFLow mode. If you download a program the core ends up in app mode but if you press the &gt;RUN button, the code runs in test mode but is not stored on the core.</p>
]]></description><link>https://community.m5stack.com/post/22535</link><guid isPermaLink="true">https://community.m5stack.com/post/22535</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 21 Oct 2023 18:49:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core2 Connection trouble after upload on Sat, 21 Oct 2023 15:31:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/59994">@valbuz</a>, This sounds correct.<br />
When you click Download your program is loaded to device and it resets, to run the program.<br />
If you want to try the program click Run for temporary load, a power cycle should clear the temporary program and UIFlow will be available again. Until you are ready to Download, you can just click Run to try your program on the device.</p>
]]></description><link>https://community.m5stack.com/post/22534</link><guid isPermaLink="true">https://community.m5stack.com/post/22534</guid><dc:creator><![CDATA[gavin67890]]></dc:creator><pubDate>Sat, 21 Oct 2023 15:31:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core2 Connection trouble after upload on Sat, 21 Oct 2023 11:06:55 GMT]]></title><description><![CDATA[<p dir="auto">After FW Upgrade i see no error and no red textes.</p>
]]></description><link>https://community.m5stack.com/post/22533</link><guid isPermaLink="true">https://community.m5stack.com/post/22533</guid><dc:creator><![CDATA[Valbuz]]></dc:creator><pubDate>Sat, 21 Oct 2023 11:06:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core2 Connection trouble after upload on Sat, 21 Oct 2023 08:07:11 GMT]]></title><description><![CDATA[<p dir="auto">Is the connected text on the bottom of UIflow turning red after you send firmware?<br />
It could be something in your program stopping the normal UIFlow from booting or it could be the server loosing connection.</p>
]]></description><link>https://community.m5stack.com/post/22531</link><guid isPermaLink="true">https://community.m5stack.com/post/22531</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 21 Oct 2023 08:07:11 GMT</pubDate></item></channel></rss>
