<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extra juicy and question about USB type C charging.]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I have been working with M5Stack since 2020, it really checking all the boxes of what I wanted for a micro controller. I am currently working with M5Stack Fire, and the battery base comes with a 500 mAh battery. However, I need more juicy to keep it running longer wirelessly. I am powering a set up of a Neoplixel ring, a RFID 2 unit, a limit Switch unity, and potentially a vibrator unit.</p>
<p dir="auto">Due to size of the housing, I decided to create a Type C power cable with following parts to keep it low profile:</p>
<p dir="auto"><img src="https://m.media-amazon.com/images/I/516GMNdvzmL._SL1200_.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://m.media-amazon.com/images/I/51RAVWf0ifL._AC_SX679_.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">I soldered the red wire to the V+ and black wire to the G. However, <strong>this DIY power cable only works when plug in with a Type C to Type A cables (power source) and not Type C to Type C (power source) cables.</strong></p>
<p dir="auto">Anyone know why this is happening? Is Type C to Type A wired differently? or is it because the 5.1K resistor?</p>
<p dir="auto">Any insight will be greatly appreciated.</p>
]]></description><link>https://community.m5stack.com/topic/5680/extra-juicy-and-question-about-usb-type-c-charging</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 21:07:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5680.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Sep 2023 18:04:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Extra juicy and question about USB type C charging. on Thu, 28 Sep 2023 19:34:50 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ghettokon" aria-label="Profile: ghettokon">@<bdi>ghettokon</bdi></a></p>
<p dir="auto">maybe related to the note at the bottom <a href="http://docs.m5stack.com/en/core/fire_v2.6" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>?</p>
<p dir="auto"><em>Note: 2018.2A PCB version of the device does not support C2C (TypeC to TypeC) connection and PD power supply.</em></p>
]]></description><link>https://community.m5stack.com/post/22360</link><guid isPermaLink="true">https://community.m5stack.com/post/22360</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 28 Sep 2023 19:34:50 GMT</pubDate></item></channel></rss>
