<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BALA2 Fire encoder question]]></title><description><![CDATA[<p dir="auto">The question is : how exactly many pulses produce encoder per 1 full revolve of the wheel ?</p>
]]></description><link>https://community.m5stack.com/topic/5676/bala2-fire-encoder-question</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 15:27:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5676.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Sep 2023 20:57:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BALA2 Fire encoder question on Tue, 03 Oct 2023 08:36:57 GMT]]></title><description><![CDATA[<p dir="auto">There is an A &amp; B pulse from each wheel.<br />
I think you'll need to acquaint yourself with Quadrature Encoders.</p>
<p dir="auto">A quick check to do:<br />
Try to make two temporary but firm mechanical stops with say 100 degrees distance (not important to know the exact angle between them) and then repeatedly move the wheel between the stops. You should get the same two values (+/- 1 or 2) every time at each stop.</p>
]]></description><link>https://community.m5stack.com/post/22400</link><guid isPermaLink="true">https://community.m5stack.com/post/22400</guid><dc:creator><![CDATA[Cognitive5525]]></dc:creator><pubDate>Tue, 03 Oct 2023 08:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to BALA2 Fire encoder question on Fri, 29 Sep 2023 15:41:16 GMT]]></title><description><![CDATA[<p dir="auto">I'm using just one wheel:<br />
// Get motor encoder value<br />
bala.UpdateEncoder();<br />
encoder = bala.wheel_left_encoder;</p>
]]></description><link>https://community.m5stack.com/post/22366</link><guid isPermaLink="true">https://community.m5stack.com/post/22366</guid><dc:creator><![CDATA[slavav]]></dc:creator><pubDate>Fri, 29 Sep 2023 15:41:16 GMT</pubDate></item><item><title><![CDATA[Reply to BALA2 Fire encoder question on Fri, 29 Sep 2023 07:54:43 GMT]]></title><description><![CDATA[<p dir="auto">Are you counting incremental with both A and B pulses?</p>
]]></description><link>https://community.m5stack.com/post/22364</link><guid isPermaLink="true">https://community.m5stack.com/post/22364</guid><dc:creator><![CDATA[Cognitive5525]]></dc:creator><pubDate>Fri, 29 Sep 2023 07:54:43 GMT</pubDate></item><item><title><![CDATA[Reply to BALA2 Fire encoder question on Thu, 28 Sep 2023 17:23:09 GMT]]></title><description><![CDATA[<p dir="auto">i actually wrote test. And it produce surprisedly big number: ~400. It is pretty difficult to adjust wheel to exactly same position after 1 revolt. So the value vary like: 415, 410, 412 ...</p>
]]></description><link>https://community.m5stack.com/post/22358</link><guid isPermaLink="true">https://community.m5stack.com/post/22358</guid><dc:creator><![CDATA[slavav]]></dc:creator><pubDate>Thu, 28 Sep 2023 17:23:09 GMT</pubDate></item><item><title><![CDATA[Reply to BALA2 Fire encoder question on Thu, 28 Sep 2023 08:05:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/54893">@slavav</a> this one:<br />
<a href="https://docs.m5stack.com/en/app/bala2fire" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/app/bala2fire</a><br />
?<br />
It seems not to appear on spec-sheet.</p>
<p dir="auto">If you have one in your possession, make a test-program to count it yourself ?</p>
]]></description><link>https://community.m5stack.com/post/22338</link><guid isPermaLink="true">https://community.m5stack.com/post/22338</guid><dc:creator><![CDATA[Cognitive5525]]></dc:creator><pubDate>Thu, 28 Sep 2023 08:05:49 GMT</pubDate></item></channel></rss>
