<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack ENV III]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am working on a school project and we have to use the ENVIII sensor. There is very little documentation about this device or at least how to use it with the M5Stack, I have only found a GitHub repository with example Arduino codes.<br />
I have tried out the <a href="https://github.com/m5stack/M5Unit-ENV/blob/master/examples/Unit_ENVIII_M5Core2/Unit_ENVIII_M5Core2.ino" target="_blank" rel="noopener noreferrer nofollow ugc">ENVIII example code</a>, which does not quite work. After a bit of fixing, I managed to get the Temp, Humidity and Pressure printed on the LCD but it just shows 0 for each. I assume they are stuck to their initial value and the sht30 functions are not working.<br />
If that can help, I am using the port A (Red).</p>
<p dir="auto">Have a good day</p>
]]></description><link>https://community.m5stack.com/topic/5644/m5stack-env-iii</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 06:17:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5644.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Sep 2023 12:08:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack ENV III on Fri, 15 Sep 2023 13:36:55 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much for your reply! I will look into UI Flow.</p>
]]></description><link>https://community.m5stack.com/post/22239</link><guid isPermaLink="true">https://community.m5stack.com/post/22239</guid><dc:creator><![CDATA[bl0__]]></dc:creator><pubDate>Fri, 15 Sep 2023 13:36:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack ENV III on Fri, 15 Sep 2023 12:56:47 GMT]]></title><description><![CDATA[<p dir="auto">The sensor works right away under UI Flow. I don't have any experience with it under C++</p>
]]></description><link>https://community.m5stack.com/post/22238</link><guid isPermaLink="true">https://community.m5stack.com/post/22238</guid><dc:creator><![CDATA[csierra67]]></dc:creator><pubDate>Fri, 15 Sep 2023 12:56:47 GMT</pubDate></item></channel></rss>
