<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Simplest way to connect temperature and flowrate sensors to Core2]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">For my project based on Core2, I need to measure water temperature and flow-rate. Temperature sensors are up to 50m from core2.</p>
<p dir="auto">The best solution is the simplest, without creating</p>
<p dir="auto">Is there a "ready to use" solution, using I2C for example or wireless? I read that I2C is low distance only.</p>
<p dir="auto">Another solution is using a module? Is there a simple module for core2 that expose all GPIO ?</p>
<p dir="auto">Last solution, simply made a cable with all my sensors, connected under the code2 by removing the little window. But witch female connector to use with gpio port under the core2 ? do you have a ref?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5568/simplest-way-to-connect-temperature-and-flowrate-sensors-to-core2</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 11:02:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5568.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Aug 2023 09:33:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Simplest way to connect temperature and flowrate sensors to Core2 on Sat, 12 Aug 2023 20:26:25 GMT]]></title><description><![CDATA[<p dir="auto">That question of which sensors to use is dependent of environmental conditions.<br />
In My case an RPI acts as an MQTT server (because I have one available), controllers capture the data from the sensors and send them Over WIFI to the MQTT on the RPI using very simple UIFLow code.</p>
<p dir="auto">This all depends on wifi range. I do have a sim module to review but I have been struggling to understand and find suitable SIM cards for MQTT/IOT use.</p>
]]></description><link>https://community.m5stack.com/post/21891</link><guid isPermaLink="true">https://community.m5stack.com/post/21891</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 12 Aug 2023 20:26:25 GMT</pubDate></item><item><title><![CDATA[Reply to Simplest way to connect temperature and flowrate sensors to Core2 on Sat, 12 Aug 2023 13:26:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks, the question is about witch hardware is the best solution. Using a an existing module, using grove port, creating a custom module?<br />
Could you provide the link to this vidéo?</p>
]]></description><link>https://community.m5stack.com/post/21887</link><guid isPermaLink="true">https://community.m5stack.com/post/21887</guid><dc:creator><![CDATA[Leo05]]></dc:creator><pubDate>Sat, 12 Aug 2023 13:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to Simplest way to connect temperature and flowrate sensors to Core2 on Sat, 12 Aug 2023 09:36:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leo05" aria-label="Profile: leo05">@<bdi>leo05</bdi></a> yes and I have a video on my YouTube channel where I send the readings from the sensors to a rpi base MQTT server and use node red to send and receive the readings and control devices based on those readings.</p>
]]></description><link>https://community.m5stack.com/post/21879</link><guid isPermaLink="true">https://community.m5stack.com/post/21879</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 12 Aug 2023 09:36:40 GMT</pubDate></item></channel></rss>
