<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stick randomly wakes from deep sleep]]></title><description><![CDATA[<p dir="auto">I tried to put the M5Stick into deep sleep and found that it randomly wakes up after a while without any trigger or timer set.<br />
I am using the Arduino IDE and tried deep sleep and light sleep and it always wakes up after a while (not constant time).<br />
I tried it on the gray and the white model with the same result. It happens with and without USB power. Any ideas as to why that happens? I just want it to sleep until reset is pressed.</p>
]]></description><link>https://community.m5stack.com/topic/554/m5stick-randomly-wakes-from-deep-sleep</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 12:59:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/554.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Jan 2019 17:25:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stick randomly wakes from deep sleep on Tue, 12 Feb 2019 04:16:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mocm" aria-label="Profile: mocm">@<bdi>mocm</bdi></a> You can talk with eggfly by github.</p>
<p dir="auto"><a href="https://github.com/eggfly" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eggfly</a></p>
]]></description><link>https://community.m5stack.com/post/2916</link><guid isPermaLink="true">https://community.m5stack.com/post/2916</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Tue, 12 Feb 2019 04:16:09 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick randomly wakes from deep sleep on Mon, 28 Jan 2019 11:45:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> said in <a href="/post/2751">M5Stick randomly wakes from deep sleep</a>:</p>
<p dir="auto"><a href="https://github.com/m5stack/StickWatch" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/StickWatch</a></p>
<p dir="auto">Thanks,<br />
I tried the StickWatch sketch and in this case the deep sleep seems to work. I compared the code, but could<br />
not see any differences. So I have to check again. Are there any sleep settings kept in SPIFFS ? If so,<br />
changing the memory config for the StickWatch sketch may have overwritten them and fixed the<br />
problem.</p>
]]></description><link>https://community.m5stack.com/post/2753</link><guid isPermaLink="true">https://community.m5stack.com/post/2753</guid><dc:creator><![CDATA[mocm]]></dc:creator><pubDate>Mon, 28 Jan 2019 11:45:54 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick randomly wakes from deep sleep on Mon, 28 Jan 2019 11:00:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mocm" aria-label="Profile: mocm">@<bdi>mocm</bdi></a><br />
How about your code?</p>
<p dir="auto">However, you can try this code for your m5stick.</p>
]]></description><link>https://community.m5stack.com/post/2751</link><guid isPermaLink="true">https://community.m5stack.com/post/2751</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 28 Jan 2019 11:00:20 GMT</pubDate></item></channel></rss>
