<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core3 12V]]></title><description><![CDATA[<p dir="auto">I'm just wondering for the CoreS3 how the 9-24V DC circuit fits in. Its mentioned in the specifications, but I can't find it on the schematic. The schematic V1.0 referenced <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/core/K128%20CoreS3/Sch_M5_CoreS3_v1.0.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/core/K128 CoreS3/Sch_M5_CoreS3_v1.0.pdf</a> found on <a href="https://docs.m5stack.com/en/core/CoreS3" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/core/CoreS3</a><br />
From a low power quiescent current, I'm curious to understand about what the draw is when AXP2101 powered off.</p>
]]></description><link>https://community.m5stack.com/topic/5538/core3-12v</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 12:48:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5538.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Aug 2023 03:40:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core3 12V on Fri, 04 Aug 2023 16:39:00 GMT]]></title><description><![CDATA[<p dir="auto">When it comes to the CoreS3, the 9-24V DC circuit mentioned in the specifications might not be present on the schematic you're looking at.</p>
]]></description><link>https://community.m5stack.com/post/21788</link><guid isPermaLink="true">https://community.m5stack.com/post/21788</guid><dc:creator><![CDATA[blackfigcurrant]]></dc:creator><pubDate>Fri, 04 Aug 2023 16:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to Core3 12V on Fri, 04 Aug 2023 03:20:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/mtylerjr" aria-label="Profile: mtylerjr">@<bdi>mtylerjr</bdi></a> thanks for the reference. Looks nice the way it plugs together.<br />
I'm looking at the power system for  low power sippping as an IoT device, mostly turned off for the ideal in power savings.<br />
The CoreS3 AXP2101 switch off looks excellent for going into low power mode.<br />
Then on the DIN base the SY8303AIC looks like a nice quiescent power supply - though if its interfacing to a 20V solar panel, would be nice to program the MPP power point with a resistor on the EN.<br />
However, seems like low power hasn't extended to the TP4057 LiIon charger - it has two LEDs - seems the RED is on when charging  which could be tolerated, and then the GREEN when its charged  - which of course is then using Green LED current as quiescent power.<br />
Thanks again for pointing me at the way if fits together :)</p>
]]></description><link>https://community.m5stack.com/post/21782</link><guid isPermaLink="true">https://community.m5stack.com/post/21782</guid><dc:creator><![CDATA[neilh20]]></dc:creator><pubDate>Fri, 04 Aug 2023 03:20:49 GMT</pubDate></item><item><title><![CDATA[Reply to Core3 12V on Thu, 03 Aug 2023 07:24:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/neilh20" aria-label="Profile: neilh20">@<bdi>neilh20</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mtylerjr" aria-label="Profile: mtylerjr">@<bdi>mtylerjr</bdi></a> is correct. The DC/DC converter is in the DIN BASE. See <a href="https://docs.m5stack.com/en/base/DIN%20BASE" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> here.</p>
]]></description><link>https://community.m5stack.com/post/21771</link><guid isPermaLink="true">https://community.m5stack.com/post/21771</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 03 Aug 2023 07:24:43 GMT</pubDate></item><item><title><![CDATA[Reply to Core3 12V on Thu, 03 Aug 2023 06:06:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neilh20" aria-label="Profile: neilh20">@<bdi>neilh20</bdi></a> I think you'll need to look at the DIN-base schematics - thats where the 24v max comes from, the base's own dc converters. And it comes attached with the CoreS3 so the webpage advertising/specifications treat them (understandably) as single unit.</p>
]]></description><link>https://community.m5stack.com/post/21769</link><guid isPermaLink="true">https://community.m5stack.com/post/21769</guid><dc:creator><![CDATA[mtylerjr]]></dc:creator><pubDate>Thu, 03 Aug 2023 06:06:08 GMT</pubDate></item></channel></rss>
