<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DIN Base battery transplant]]></title><description><![CDATA[<p dir="auto">I just wanted to mention that It is possible to transplant the 1500 mah lipo battery, from the "13.2 battery module", and squeeze it into the "DIN Base" (replacing its smaller 500mah battery.)<br />
It is a very  tight fit - and I did remove the two small spongy spacers and clear plastic barrier [that seems to exist to protect the battery from too-long-screws from the bottom], so there is less physical protection and the warranty is voided obviously - but now I have a more compact CoreS3/Din Base combo, with triple the mAh to last longer unplugged without the additional height of the 13.2 battery module.</p>
<p dir="auto">It may not matter to most, but It is a workable, if unsupported, DIY option (if height needs to be limited)</p>
]]></description><link>https://community.m5stack.com/topic/5482/din-base-battery-transplant</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 06:48:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5482.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Jul 2023 00:53:01 GMT</pubDate><ttl>60</ttl></channel></rss>
