<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Write&#x2F;Read Data(SD Card or internal) into the CoreS3 with Uiflow 2.0]]></title><description><![CDATA[<p dir="auto">Hi, i'm new in m5stack in general and i need to save the parameters changed by the user in the UI, to the internal or SD Card storage to read them later in a following start of the device. I see that this can be done in Uiflow 1 but in uiflow 2.0 i don't see the SD Card blocks to accomplish this. Any help with this would be gracefull</p>
]]></description><link>https://community.m5stack.com/topic/5441/write-read-data-sd-card-or-internal-into-the-cores3-with-uiflow-2-0</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 19:59:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5441.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Jun 2023 07:33:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Write&#x2F;Read Data(SD Card or internal) into the CoreS3 with Uiflow 2.0 on Thu, 29 Jun 2023 18:14:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">Here is an explanation as to why it may take some time to fix: M5CoreS3 uses the SPI bus in a special way to control the LCD: MISO (normally an input) is reconfigured to be an <strong>output</strong> and is used as DC line (instead of a dedicated GPIO for DC). Unfortunately to access the SD card (which shares the SPI bus with the LCD) MISO needs to be an <strong>input</strong>.</p>
<p dir="auto">In case you might be interested. I found a way to do this switching back and forth between input and output for <a href="https://community.m5stack.com/topic/5415/core-s3-sd-tf-card-issues/2">Arduino</a>.</p>
]]></description><link>https://community.m5stack.com/post/21397</link><guid isPermaLink="true">https://community.m5stack.com/post/21397</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 29 Jun 2023 18:14:53 GMT</pubDate></item><item><title><![CDATA[Reply to Write&#x2F;Read Data(SD Card or internal) into the CoreS3 with Uiflow 2.0 on Thu, 29 Jun 2023 15:35:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alejandro_baup" aria-label="Profile: alejandro_baup">@<bdi>alejandro_baup</bdi></a> I have been asking for a few weeks but there looks to be an issue with sdxards at present</p>
]]></description><link>https://community.m5stack.com/post/21396</link><guid isPermaLink="true">https://community.m5stack.com/post/21396</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 29 Jun 2023 15:35:37 GMT</pubDate></item></channel></rss>
