<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CoreS3 internal battery?]]></title><description><![CDATA[<p dir="auto">I just received my CoreS3. The documentation and the device's box mentioned a 500 mAh internal battery. However, I am unable to 1) find the battery in the device and 2) launch the device without it being plugged in.</p>
<p dir="auto">Going into the power tab of the demo software, I see 0.0V for the battery... Which to me would indicate the absence of a battery.</p>
<p dir="auto">Since the documentation mentions the internal battery, I assume I have a defective unit that was shipped without it or am I mistaken?</p>
]]></description><link>https://community.m5stack.com/topic/5376/cores3-internal-battery</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 05:37:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5376.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Jun 2023 00:53:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CoreS3 internal battery? on Thu, 13 Jul 2023 01:01:44 GMT]]></title><description><![CDATA[<p dir="auto">I also faced this problem.<br />
In my case, battery was fine, but connector was bad.<br />
Please check battery and pcb voltage.</p>
]]></description><link>https://community.m5stack.com/post/21560</link><guid isPermaLink="true">https://community.m5stack.com/post/21560</guid><dc:creator><![CDATA[nathan 0]]></dc:creator><pubDate>Thu, 13 Jul 2023 01:01:44 GMT</pubDate></item><item><title><![CDATA[Reply to CoreS3 internal battery? on Sat, 10 Jun 2023 09:37:46 GMT]]></title><description><![CDATA[<p dir="auto">Yes as <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> has said.<br />
The battery is located in the base under the pcb. The base must be switched on to charge and use the battery.</p>
]]></description><link>https://community.m5stack.com/post/21156</link><guid isPermaLink="true">https://community.m5stack.com/post/21156</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 10 Jun 2023 09:37:46 GMT</pubDate></item><item><title><![CDATA[Reply to CoreS3 internal battery? on Sat, 10 Jun 2023 08:18:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/44270">@pefortin</a></p>
<p dir="auto">the battery is in the base part of the M5CoreS3. Next to the DC input is the battery switch. See <a href="https://docs.m5stack.com/en/core/CoreS3" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>. In order to run the M5CoreS3 from battery (or charge the battery) the battery switch needs to be in the <code>ON</code> position.</p>
<p dir="auto">The battery might be low - so try charging it first.</p>
]]></description><link>https://community.m5stack.com/post/21152</link><guid isPermaLink="true">https://community.m5stack.com/post/21152</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 10 Jun 2023 08:18:54 GMT</pubDate></item></channel></rss>
