<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PSA: Core 2 not powering off.]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: M5Stack">@<bdi>M5Stack</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/iamliubo" aria-label="Profile: IAMLIUBO">@<bdi>IAMLIUBO</bdi></a><br />
You may notice that sometime Core2 device may not power off when the button is held in for five seconds.<br />
I have noticed that the Button used for power is prone to breaking (I have already notified M5Stack about this issue on multiple occasions)<br />
You can replace the switch but a simpler fix is to use the "battery paper trick" and stick a small block of insulated substance on top of the switch to hold the cover down.</p>
<p dir="auto">I haven't included pictures as the switch is so small and difficult to photograph.</p>
<p dir="auto">P.S. This doesn't just affect Core2 devices and any device that uses this switch may suffer.<br />
Thank you for taking the Time to Read.</p>
<p dir="auto">Adam Bryant<br />
Forum Admin Team and Unofficial documentation and guide creator.</p>
]]></description><link>https://community.m5stack.com/topic/5299/psa-core-2-not-powering-off</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 12:11:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5299.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 May 2023 07:19:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PSA: Core 2 not powering off. on Fri, 13 Jun 2025 01:09:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/20846">PSA: Core 2 not powering off.</a>:</p>
<p dir="auto">You may notice that sometimes the Core2 device may not power off when the button is held in for five seconds.<br />
You can replace the switch, but a simpler fix is to use the "battery paper trick" and stick a small block of insulated substance on top of the switch to hold the cover down.</p>
<p dir="auto">P.S. This doesn't just affect Core2 devices, and any device that uses this switch may suffer.<br />
Thank you for taking the Time treadad.</p>
<p dir="auto">UIFlow, so easy an adult can learn it!<br />
If I don't know it, be patient!<br />
I've either not learned it or am too drunk to remember it!<br />
Author of the WIP UIFlow Handbook!<br />
M5Black, Go, Stick, Core2, and so much more, it can't fit in here!</p>
<p dir="auto">Thanks for the heads-up, Adam. I’ve run into the same issue a couple of times and thought it was just me not holding the button long enough. Good to know it might be a hardware fault. I’ll give the battery paper trick a try and see if that helps. Appreciate you sharing the workaround and letting M5Stack know, hopefully they address it in future batches.</p>
]]></description><link>https://community.m5stack.com/post/29239</link><guid isPermaLink="true">https://community.m5stack.com/post/29239</guid><dc:creator><![CDATA[Slarck]]></dc:creator><pubDate>Fri, 13 Jun 2025 01:09:53 GMT</pubDate></item></channel></rss>
