<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t get working core2 with ac power base]]></title><description><![CDATA[<p dir="auto">Hi all!<br />
I bought a couple of ac power bases and core2 controllers, connected them and can't get them to work. When connecting 220 volts, the controller does not turn on and clicks are periodically heard. When I power the controllers via usb, they work great. Can anyone help me connect?</p>
]]></description><link>https://community.m5stack.com/topic/5270/can-t-get-working-core2-with-ac-power-base</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 08:36:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5270.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 May 2023 19:50:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t get working core2 with ac power base on Fri, 16 Jun 2023 00:35:05 GMT]]></title><description><![CDATA[<p dir="auto">I am having exactly the same problem, were you able to figure out how it works? <a class="plugin-mentions-user plugin-mentions-a" href="/user/past" aria-label="Profile: Past">@<bdi>Past</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/21211</link><guid isPermaLink="true">https://community.m5stack.com/post/21211</guid><dc:creator><![CDATA[jmillfd]]></dc:creator><pubDate>Fri, 16 Jun 2023 00:35:05 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t get working core2 with ac power base on Mon, 22 May 2023 18:20:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
Thank you Felix!</p>
]]></description><link>https://community.m5stack.com/post/20921</link><guid isPermaLink="true">https://community.m5stack.com/post/20921</guid><dc:creator><![CDATA[Past]]></dc:creator><pubDate>Mon, 22 May 2023 18:20:11 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t get working core2 with ac power base on Sun, 07 May 2023 14:09:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/past" aria-label="Profile: Past">@<bdi>Past</bdi></a></p>
<p dir="auto">hmm, not sure what is going on then and unfortunately I cannot try this myself as I don't have an ac power base on hand. Sorry.</p>
<p dir="auto">Maybe check with M5Stack support directly?</p>
]]></description><link>https://community.m5stack.com/post/20776</link><guid isPermaLink="true">https://community.m5stack.com/post/20776</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 07 May 2023 14:09:53 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t get working core2 with ac power base on Sun, 07 May 2023 09:34:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> I have ported <a href="https://github.com/pastukhov/esphome-axp192/blob/master/components/axp192/axp192.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">all the lib</a> without success</p>
]]></description><link>https://community.m5stack.com/post/20772</link><guid isPermaLink="true">https://community.m5stack.com/post/20772</guid><dc:creator><![CDATA[Past]]></dc:creator><pubDate>Sun, 07 May 2023 09:34:16 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t get working core2 with ac power base on Fri, 05 May 2023 20:59:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
I'm using esphome framework, but try with links, you provided, tomorrow. Thanks!</p>
]]></description><link>https://community.m5stack.com/post/20761</link><guid isPermaLink="true">https://community.m5stack.com/post/20761</guid><dc:creator><![CDATA[Past]]></dc:creator><pubDate>Fri, 05 May 2023 20:59:36 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t get working core2 with ac power base on Fri, 05 May 2023 20:51:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/past" aria-label="Profile: Past">@<bdi>Past</bdi></a></p>
<p dir="auto">upon starting up the M5Core2 5 V pin on the M5Stack bus is set as input, then depending on the program running, the 5 V pin might be switched to an output. If that is the case, then the M5Core2 keeps restarting as it shuts itself off, as soon as the 5 V pin is switched to an output.</p>
<p dir="auto">however if you use the latest Arduino M5Core2 library for your program, there is an automatic detection for external power and if present the 5 V pin is kept as an input. See <a href="https://github.com/m5stack/M5Core2/blob/master/src/AXP192.cpp#L65" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/20760</link><guid isPermaLink="true">https://community.m5stack.com/post/20760</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 05 May 2023 20:51:32 GMT</pubDate></item></channel></rss>
