<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CM4 Stack Issues from the very start.]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/iamliubo" aria-label="Profile: IAMLIUBO">@<bdi>IAMLIUBO</bdi></a><br />
I have just started on the CM4 and already have issues.<br />
1, The info display on the actual screen has vanished after update,<br />
2, The clock example on GitHub does not work on a fresh CM4 Stack</p>
]]></description><link>https://community.m5stack.com/topic/5201/cm4-stack-issues-from-the-very-start</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 03:02:38 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5201.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Apr 2023 13:17:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CM4 Stack Issues from the very start. on Mon, 10 Apr 2023 05:45:23 GMT]]></title><description><![CDATA[<p dir="auto">No it was from this place:<br />
<a href="https://github.com/m5stack/m5stack-linux-dtoverlays/tree/main/examples" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/m5stack-linux-dtoverlays/tree/main/examples</a></p>
<p dir="auto">The issue is actually a dependence missing from the install instructions (user writeup error) fixed with adding the following command:</p>
<p dir="auto"><code>sudo apt-get install qtdeclarative5-dev</code></p>
<p dir="auto">before running</p>
<p dir="auto"><code>cmake .. &amp;&amp; make </code></p>
]]></description><link>https://community.m5stack.com/post/20558</link><guid isPermaLink="true">https://community.m5stack.com/post/20558</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 10 Apr 2023 05:45:23 GMT</pubDate></item><item><title><![CDATA[Reply to CM4 Stack Issues from the very start. on Sun, 09 Apr 2023 20:35:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> is that the <a href="https://github.com/m5stack/CM4Stack_lvgl/blob/Basic/main.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/CM4Stack_lvgl/blob/Basic/main.cpp</a><br />
Or something else?</p>
]]></description><link>https://community.m5stack.com/post/20556</link><guid isPermaLink="true">https://community.m5stack.com/post/20556</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sun, 09 Apr 2023 20:35:01 GMT</pubDate></item></channel></rss>
