<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotary encoder on M5Stack - interrupts?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am using an M5Stack to develop a WiFi throttle for model trains. All works fine and I can connect and drive a locomotive whilst being connected to a Märklin CS3.</p>
<p dir="auto">However I am struggling to use a rotary encoder to control the speed. My current code is not using interrupts and struggling with bouncing. I am trying to use interrupts, but to me it looks like those are not recognized.</p>
<p dir="auto">I suspect I am not using the right ports. Any hint would be welcome.</p>
<p dir="auto">Many thanks in advance</p>
<p dir="auto">Jörg</p>
]]></description><link>https://community.m5stack.com/topic/516/rotary-encoder-on-m5stack-interrupts</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 19:38:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/516.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Jan 2019 11:52:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotary encoder on M5Stack - interrupts? on Mon, 28 Jan 2019 21:22:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">sorry about the delay in answering, but I have been really busy with my real life job.</p>
<p dir="auto">The rotary encoder (ALPS STEC12E07) is connected to pins 2 and 3 of the M5Stack and GND.</p>
<p dir="auto">I also have used pins 22 and 23 in the past, but those can crash the app as soon as you are using the TFT of the M5Stack (looked into the header files of M5Stack and found that pin 22 is connected to the TFT).</p>
<p dir="auto">I am using the following code, which you can find in variations on the web:</p>
<p dir="auto">/* Read Quadrature Encoder<br />
Connect Encoder to Pins encoder0PinA, encoder0PinB, and +5V.</p>
<p dir="auto">Sketch by max wolf / <a href="http://www.meso.net" target="_blank" rel="noopener noreferrer nofollow ugc">www.meso.net</a><br />
v. 0.1 - very basic functions - mw 20061220</p>
<p dir="auto">*/</p>
<p dir="auto">int encoder0PinA = 2;<br />
int encoder0PinB = 3;</p>
<p dir="auto">int encoderPos = 0;<br />
int lastReportedPos = 0;</p>
<p dir="auto">int aValue = LOW;<br />
int bValue  = LOW;<br />
int aValueLast = LOW;</p>
pinMode (encoder0PinA, INPUT);<br />
pinMode (encoder0PinB, INPUT);<br />
digitalWrite(encoder0PinA, LOW);<br />
digitalWrite(encoder0PinB, LOW);</p>
<p dir="auto">encoderPos = 2000;</p>
<p dir="auto">Serial.begin (115200);</p>
<p dir="auto">}</p>
<p dir="auto">void loop() {</p>
<p dir="auto">delay(5);</p>
<p dir="auto">aValue = digitalRead(encoder0PinA);<br />
bValue = digitalRead(encoder0PinB);</p>
<p dir="auto">if ((aValue != aValueLast) &amp;&amp; (aValue == LOW)) {              //knob rotated, when aValues changes, BUT use only if aValue is LOW</p>
<pre><code>if (bValue == LOW) {
  encoderPos++;
} else {
  encoderPos--;
<p dir="auto">}</p>
<p dir="auto">aValueLast = aValue;</p>
<p dir="auto">if(lastReportedPos != encoderPos)<br />
{</p>
<pre><code> Serial.print("Position: ");
 Serial.println(encoderPos, DEC);
  lastReportedPos = encoderPos;
<p dir="auto">}</p>
<p dir="auto">The code works from time to time, but its not reliable on the M5Stack. Tomorrow I will buy another rotary encoder just to exclude any hardware issues.</p>
<p dir="auto">Kind regards<br />
Jörg</p>
]]></description><link>https://community.m5stack.com/post/2757</link><guid isPermaLink="true">https://community.m5stack.com/post/2757</guid><dc:creator><![CDATA[New_Comix]]></dc:creator><pubDate>Mon, 28 Jan 2019 21:22:28 GMT</pubDate></item><item><title><![CDATA[Reply to Rotary encoder on M5Stack - interrupts? on Tue, 22 Jan 2019 04:36:22 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like a cool project Jorg. As <a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> asked please provide us with more information so we can help you with the issue.</p>
<p dir="auto">Specifically what programming environment are you using?  Arduino, Micropython, Uiflow?</p>
<p dir="auto">Please provide us with the code if you don't mind sharing it</p>
<p dir="auto">A schematic, or if its simply hooked up to the pins of the m5stack without any other components, please tell us the pins you used.  Perhaps including the model of the encoder you are using could also help to</p>
<p dir="auto">Thanks</p>
<p dir="auto">Lukas</p>
]]></description><link>https://community.m5stack.com/post/2623</link><guid isPermaLink="true">https://community.m5stack.com/post/2623</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 22 Jan 2019 04:36:22 GMT</pubDate></item><item><title><![CDATA[Reply to Rotary encoder on M5Stack - interrupts? on Mon, 21 Jan 2019 04:34:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/new_comix" aria-label="Profile: new_comix">@<bdi>new_comix</bdi></a><br />
Hello, specific description please.</p>
]]></description><link>https://community.m5stack.com/post/2589</link><guid isPermaLink="true">https://community.m5stack.com/post/2589</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 21 Jan 2019 04:34:51 GMT</pubDate></item></channel></rss>
