<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I enter BOOT mode on M5Core2: Wrong boot mode detected (0x0)! The chip needs to be in download mode]]></title><description><![CDATA[<p dir="auto">Having a nightmare with my new M5Core23 device which decided it no longer wanted to play!  It has been working for the first few days but as of today I am unable to restore the factory image using M5Burner, and any sketch I load into ArduinoIDE simply does not upload.  I see nothing on the screen even when plugged into USB.</p>
<p dir="auto">I have uninstalled and reinstalled the correct serial port drivers, restarted my Mac and still get nothing.</p>
<p dir="auto">So... how do I enter BOOT mode on the M5Core2 please?  I gather on the M5Stack it was via one of the three hardware buttons, which I believe have been replaced by the three built in touch screen software buttons on the M5Core2.  So, does this mean I need to open up the device and wire whichever the BOOT pin is to ground when I upload? Is that the way to get this device into BOOT mode?</p>
<p dir="auto">if so, what is the BOOT pin I should ground for the M5Core2 please?</p>
<p dir="auto">Hoping someone can help.  Many thanks.</p>
]]></description><link>https://community.m5stack.com/topic/5149/how-do-i-enter-boot-mode-on-m5core2-wrong-boot-mode-detected-0x0-the-chip-needs-to-be-in-download-mode</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 22:21:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5149.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Mar 2023 18:26:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I enter BOOT mode on M5Core2: Wrong boot mode detected (0x0)! The chip needs to be in download mode on Thu, 23 Mar 2023 19:24:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> said in <a href="/post/20427">How do I enter BOOT mode on M5Core2: Wrong boot mode detected (0x0)! The chip needs to be in download mode</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/36793">@themusicman</a> This means that something else in OSX is access the USBport via a terminal preventing M5Burner from being able to access the port.</p>
<p dir="auto">Please make sure only M5Burner is running and that no other terminal software is running.</p>
<p dir="auto">I tried on my MacBookPro (<em>original issue was on iMac</em>) with no other serial terminal software running, exactly the same issues unfortunately.  I have now returned the M5Core2 device back to thePiHut and am awaiting a replacement.</p>
<p dir="auto">Thanks for your support though <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> - it is much appreciated.</p>
]]></description><link>https://community.m5stack.com/post/20429</link><guid isPermaLink="true">https://community.m5stack.com/post/20429</guid><dc:creator><![CDATA[theMusicMan]]></dc:creator><pubDate>Thu, 23 Mar 2023 19:24:27 GMT</pubDate></item><item><title><![CDATA[Reply to How do I enter BOOT mode on M5Core2: Wrong boot mode detected (0x0)! The chip needs to be in download mode on Thu, 23 Mar 2023 18:21:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/36793">@themusicman</a> This means that something else in OSX is access the USBport via a terminal preventing M5Burner from being able to access the port.</p>
]]></description><link>https://community.m5stack.com/post/20427</link><guid isPermaLink="true">https://community.m5stack.com/post/20427</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 Mar 2023 18:21:41 GMT</pubDate></item><item><title><![CDATA[Reply to How do I enter BOOT mode on M5Core2: Wrong boot mode detected (0x0)! The chip needs to be in download mode on Tue, 21 Mar 2023 21:03:31 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a></p>
<p dir="auto">I tried this earlier too, these are the results of trying that... any suggestions?</p>
<p dir="auto"><a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v3.3.2-dev<br />
Serial port /dev/tty.wchusbserial54FC0182651<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/serial/serialposix.py", line 265, in open<br />
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)<br />
OSError: [Errno 16] Resource busy: '/dev/tty.wchusbserial54FC0182651'</p>
<p dir="auto">During handling of the above exception, another exception occurred:</p>
<p dir="auto">Traceback (most recent call last):<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 5399, in &lt;module&gt;<br />
_main()<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 5392, in _main<br />
main()<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 4699, in main<br />
esp = esp or get_default_connected_device(ser_list, port=args.port, connect_attempts=args.connect_attempts,<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 110, in get_default_connected_device<br />
_esp = ESPLoader.detect_chip(each_port, initial_baud, before, trace,<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 363, in detect_chip<br />
detect_port = ESPLoader(port, baud, trace_enabled=trace_enabled)<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 320, in <strong>init</strong><br />
self._port = serial.serial_for_url(port)<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/serial/<strong>init</strong>.py", line 88, in serial_for_url<br />
instance.open()<br />
File "/Applications/M5Burner.app/Contents/Resources/packages/tool/serial/serialposix.py", line 268, in open<br />
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))<br />
serial.serialutil.SerialException: [Errno 16] could not open port /dev/tty.wchusbserial54FC0182651: [Errno 16] Resource busy: '/dev/tty.wchusbserial54FC0182651'</p>
]]></description><link>https://community.m5stack.com/post/20404</link><guid isPermaLink="true">https://community.m5stack.com/post/20404</guid><dc:creator><![CDATA[theMusicMan]]></dc:creator><pubDate>Tue, 21 Mar 2023 21:03:31 GMT</pubDate></item><item><title><![CDATA[Reply to How do I enter BOOT mode on M5Core2: Wrong boot mode detected (0x0)! The chip needs to be in download mode on Tue, 21 Mar 2023 20:52:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/36793">@themusicman</a> No need to open anything. Cold boot the Mac and try to erase the M5Core2 in M5Burner BEFORE trying to write new firmware.</p>
]]></description><link>https://community.m5stack.com/post/20402</link><guid isPermaLink="true">https://community.m5stack.com/post/20402</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 21 Mar 2023 20:52:20 GMT</pubDate></item></channel></rss>
