<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 Screen Blank - 5March2023]]></title><description><![CDATA[<p dir="auto">I have two new M5StackCore2 devices; and the screen has gone blank on one unit after I loaded the Demo program.</p>
<p dir="auto">I was able to use M5Burner to burn UIFlow_Core2 and to try some simple UI_Flow blockly programs successfully.  I was able to program ButtonA and ButtonB to show different messages on the screen.</p>
<p dir="auto">I tried to download the demo program and my Core2 screen went blank.</p>
<p dir="auto">I have tried the following fixes unsuccessfully:</p>
<li>used M5Burner to erase flash and burn a new copy of UIFlow_Core2</li>
<li>used M5Burner to erase flash and load Core2FactoryTest (I read on the forum that can be a problem)</li>
<li>used M5Burner to load M5Core2TouchPanelRecovery (my screen was blank, so I had to blindly use the power button to go through the two selections to write new model FW)</li>
<p dir="auto">At this point I can write small blockly test programs that use Button A and Button B to cycle the vibrator on and off - which seems to imply everything else is working.  However if I add a simple block to write a single label to the screen, I see nothing on the display (and the button test code will stop working to use Button A/B to cycle the vibrator).</p>
]]></description><link>https://community.m5stack.com/topic/5104/core2-screen-blank-5march2023</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 21:11:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5104.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Mar 2023 20:21:48 GMT</pubDate><ttl>60</ttl></channel></rss>
