<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wiring of M5Stack Mini Infrared Emitter &amp; Receiver Unit]]></title><description><![CDATA[<p dir="auto">Dear all,</p>
<p dir="auto">I bought the <a href="https://docs.m5stack.com/en/unit/ir" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack Mini Infrared Emitter &amp; Receiver Unit</a>.</p>
<p dir="auto">Now I attached it to the M5stack Atom Lite. According to the sticker, I would assume that one needs to connect the "white" line with the TX port and the "yellow" line with the RX line, see the <a href="https://static-cdn.m5stack.com/resource/docs/products/unit/ir/ir_02.webp" target="_blank" rel="noopener noreferrer nofollow ugc">image</a>.</p>
<p dir="auto">For some reason I do not understand, I have to switch the TX and RX lines to get the device working. Can somebody confirm?</p>
<p dir="auto">I also post the question <a href="https://community.home-assistant.io/t/wiring-of-m5stack-mini-infrared-emitter-receiver-unit-and-atom-lite/530937" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">Thanks and best wishes,<br />
Tobias</p>
]]></description><link>https://community.m5stack.com/topic/5037/wiring-of-m5stack-mini-infrared-emitter-receiver-unit</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 19:22:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5037.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Feb 2023 21:20:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wiring of M5Stack Mini Infrared Emitter &amp; Receiver Unit on Sun, 05 Feb 2023 23:28:00 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you have to "switch" the lines between the IR Unit and the Atom :<br />
One side is Tx -&gt; RX, the other side RX -&gt; TX</p>
<li>
<p dir="auto">White line: IR Unit receives the signal and transmitts it(TX, marked "data" IN) ) to the Atom,. Atom is receiver (RX), (G32 as input)</p>
</li>
<li>
<p dir="auto">Yellow line: Atom is the sender (TX) (G26 as output), IR Unit receives the data (RX) (marked "data" OUT) and transmitts the signal via IR (25Hz carrier) Check if it works with a mobile phone camera ...</p>
</li>
]]></description><link>https://community.m5stack.com/post/20024</link><guid isPermaLink="true">https://community.m5stack.com/post/20024</guid><dc:creator><![CDATA[crami25]]></dc:creator><pubDate>Sun, 05 Feb 2023 23:28:00 GMT</pubDate></item></channel></rss>
