<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom Motion motors work inconsistently]]></title><description><![CDATA[<p dir="auto">I'm noticing that even with the example sketch (<a href="https://github.com/m5stack/M5Atom/tree/master/examples/ATOM_BASE/ATOM_Motion" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Atom/tree/master/examples/ATOM_BASE/ATOM_Motion</a>) the two motors (pins M1, M2) turn inconsistently.  Sometimes a positive speed (+100) will result in motion, and likewise with a negative speed (-100).  But just as often the write will result in a high-pitched tone from the motor, but no motion.  Writing zero always stops both motors.  Has anyone else experienced this, and can you offer any insight/ideas?</p>
]]></description><link>https://community.m5stack.com/topic/5009/atom-motion-motors-work-inconsistently</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 10:49:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5009.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Jan 2023 03:52:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atom Motion motors work inconsistently on Sat, 12 Oct 2024 07:47:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/toastedcode" aria-label="Profile: toastedcode">@<bdi>toastedcode</bdi></a> did you figured out programming m5stack tough unit.  I am newbie and looking for some help on programming it by block diagram in webui</p>
<p dir="auto">Specifically looking to connect rs485 sensor output from my water level device and pressure transducer thenconvey data by matt to server</p>
<p dir="auto">Any help or step by step programming video would be great</p>
]]></description><link>https://community.m5stack.com/post/26699</link><guid isPermaLink="true">https://community.m5stack.com/post/26699</guid><dc:creator><![CDATA[aiconnection]]></dc:creator><pubDate>Sat, 12 Oct 2024 07:47:07 GMT</pubDate></item></channel></rss>
