<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I clear the UI Flow API KEY: prompt without resetting the unit?]]></title><description><![CDATA[<p dir="auto">If I don't catch the startup menu in the first second it loads the Wifi connection and lands at the screen with the API KEY displayed with instructions to load the online IDE for UI Flow. Can this screen be cleared to get the menu back or do I have to reset the unit and try again?</p>
<p dir="auto">Thanks in advance : )</p>
]]></description><link>https://community.m5stack.com/topic/4985/can-i-clear-the-ui-flow-api-key-prompt-without-resetting-the-unit</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 06:17:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4985.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Jan 2023 19:17:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I clear the UI Flow API KEY: prompt without resetting the unit? on Tue, 17 Jan 2023 19:35:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/32795">@davidjmcclelland</a> If you connect to the core using M5Burner then click on the yellow "config" button to change boot up.</p>
]]></description><link>https://community.m5stack.com/post/19890</link><guid isPermaLink="true">https://community.m5stack.com/post/19890</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 17 Jan 2023 19:35:35 GMT</pubDate></item></channel></rss>
