<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New User: Core 2 screen blinking -solved]]></title><description><![CDATA[<p dir="auto">Background: received today -<br />
followed start guide for UIFlow_Core2,<br />
USB to Windows 10 machine<br />
burned and started OK. Configurated OK.<br />
I had not run any programs and there is no sdcard.<br />
verified correct USB driver via code on unit.</p>
<p dir="auto">Issue: At some point the screen turned white and then faded quickly to black, and continued doing this black-white-black. I reset and restarted and it resumed after boot - no start menu, no beep.</p>
<p dir="auto">The only fix so far is to re-burn</p>
<p dir="auto">To repro issue, I found that when I opened the configurator after re-burning, the same blinking commenced after reading settings. Not sure if it was truly a repro or coincidence.</p>
<p dir="auto">Question 1: what is going on here? Is this known?</p>
<p dir="auto">Question 2:<br />
I would like to verify that the device is on my Wifi: I entered the settings from my PC to connect while burning, but I do not see the device on my router. What am I missing?</p>
<p dir="auto">Thanks from a newbie!</p>
]]></description><link>https://community.m5stack.com/topic/4980/new-user-core-2-screen-blinking-solved</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 02:13:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4980.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Jan 2023 20:28:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New User: Core 2 screen blinking -solved on Tue, 17 Jan 2023 19:13:02 GMT]]></title><description><![CDATA[<p dir="auto">This has not happened since I posted this question so I am going to mark it solved. I also got an answer to question 2 and am off and running with the device despite not getting any answers here.</p>
]]></description><link>https://community.m5stack.com/post/19888</link><guid isPermaLink="true">https://community.m5stack.com/post/19888</guid><dc:creator><![CDATA[davidjmcclelland]]></dc:creator><pubDate>Tue, 17 Jan 2023 19:13:02 GMT</pubDate></item></channel></rss>
